Improving throttle/spoolup response
Old May 4, 2017 | 07:33 AM
superslow's Avatar
superslow is infamous around these parts
Lightweight flywheel and catless exhaust
Old May 4, 2017 | 10:14 AM
SamboTT@ByDesign's Avatar
Don't recommend firmer springs on billet VTG's. Under boost the car is under full control and manifold pressure. Like maestro said it's good for Trans Ams but hard on the turbo charger's compressor side.
Old May 8, 2017 | 01:04 AM
Webspoke's Avatar
Webspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond repute
Originally Posted by M3 Maestro
Don't want to keep the BOV war going but I believe webspoke only swapped the springs. Borg Warner offers stiffer springs for the OEM recirc valves we have. In theory I agree it can help during transients.
I haven't tried them myself. I believe they are sold in the aftermarket under their EFR line.
That's correct, much stiffer springs (like 4x), working with the stock diaphragm. The goal was to improve transient response, in slalom like maneuvers where you are cycling on and off the throttle, and also between shifts. The brv still cycles, you can hear it on hard lifts/braking. Datalogs show 1-3 psi left in the system in the first second or two after closing the throttle. Before it was 0 or in vacuum. No side effects noticed in casual driving.
