DSC Sport Tuning Academy
Old May 9, 2017 | 06:58 AM
DSC Sport's Avatar
DSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to beholdDSC Sport is a splendid one to behold
Welcome to the DSC Sport Tuning Academy, a YouTube series in which we will be releasing step-by-step tutorials on navigating the software and how to perform specific functions.
Note: the DSC Sport Tuning Software is intended for use with Windows 7 and Windows 10 operating systems.
Lesson Guide
Old May 9, 2017 | 06:59 AM
DSC Sport's Avatar
Lesson 101 - "Downloading, Installing, and Establishing Communication"
In the first episode of the DSC Sport Tuning Academy, Jordan walks you through how to download and install the tuning software and USB driver, as well as establishing communication between the software and controller using the "Read All" function.
DSC Sport's Avatar
Lesson 105 - "Reading, Writing, and Checking your Firmware Version"
In these week's Tuning Academy lesson, Jordan walks you through how to Read your .pdts (calibration) file, write a new .pdts file, and check your firmware version.
Old May 9, 2017 | 07:21 AM
any news about launch mode for the 997 platform?
#TeamAIM
Old May 9, 2017 | 05:55 PM
trbofvr's Avatar
trbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud of
^This
Old May 11, 2017 | 04:55 AM
997.1 TT's Avatar
997.1 TT is infamous around these parts
Need to keep an eye on this thread. This will be my next mod.
Old May 17, 2017 | 04:54 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Looks good !
Old May 17, 2017 | 06:28 PM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
I gotta test that on my DSC sport
Would I get more range or parameters with B16 Belstien?
Old May 19, 2017 | 10:27 AM
DSC Sport's Avatar
The advantage of the Bilstein B16 package is not in any expanded range or parameters. They utilize the same valve design as the rest of the Bilstein (and thus OEM) dampers. The advantage of the Bilstein B16 is that of any "coilover" package, in having choices in spring rate and the ability to set ride height and corner balance. For example, the standard B16 997 Turbo package features a 260lb front spring and 650lb rear spring. The 997 GT2 package features a 330lb front spring and a 720lb rear spring.
If you want increased range, Tractive Suspension is the option here. Having a 2000-200 mA range compared to the Bilstein range of 1500-500 mA.
Old May 19, 2017 | 10:32 AM
DSC Sport's Avatar
Lesson 103 - "Troubleshooting a Connection Error"
We're back with another episode of the DSC Sport Tuning Academy! In Lesson 103, we walk you through how to troubleshoot a connection error.
Particularly on initial installation, some users experience difficulty establishing communication with the DSC Sport Tuning Software. This is usually due to a mismatch between the COM Port your computer is using for the CP210x USB driver and the COM Port the DSC Sport Tuning Software is looking for. In this lesson, we walk you through how to match your computer's COM Port settings to that of the Tuning Software. Reminder: Always close out of the Tuning Software and disconnect and reconnect the DSC Sport controller after making any COM Port changes!
Old Aug 18, 2017 | 01:44 PM
DSC Sport's Avatar
Lesson 110 - "Checking & Updating Firmware"
In this week's lesson, we walk you through how to check and update your firmware version for your DSC Sport controller.
OVERVIEW:
1. Unplug DSC from vehicle, or make sure you leave vehicle ignition off for entire firmware update process.
2. Download DSC Sport Utility
3. Download Firmware file for your vehicle
4. Save your current .pdts file if you wish to continue using it after you update your firmware.
5. Open DSC Utility, browse for firmware file, check "Firmware and EEprom, and click "Install"
6. Unplug DSC controller from power
7. Plug controller back in, open saved .pdts file, and write to controller if desired.
Old Aug 18, 2017 | 01:45 PM
DSC Sport's Avatar
Lesson 125 - "Datalogging With the Record Function"
In today's DSC Sport Tuning Academy Lesson, learn how to use the Record function to perform basic datalogging in the DSC Sport Tuning Software.
