Staring issues - sudden crank stop
Old May 10, 2017 | 01:47 PM
RickRST's Avatar
RickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to allRickRST is a name known to all
997.1 Turbo, cranks farly quickly but very often hot or cold it will stop cranking before it has started. I need to repeat 3 or 4 times before it starts. I have bypassed the clutch switch to rule that out. Next to check are the relays to see what voltage they are seeing and if power is being cut.
Can anyone help with relay locations and wiring diagrams?
Thanks, Rick
