How to shut off PASM etc PIWIS?
Old Jun 25, 2017 | 06:09 AM
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
Recently replaced stock PASM shocks with Ohlins,.. and now have a PASM Failure message on the dash.
-So I need to have PASM de-activated
-Also I want to disable the seat-belt warning.
-And activate heated seats.
BUT,.. I went to the dealer and the master tech there says it's not that simple,.. blah, blah, blah.
But here it sounds like you just go into the ECU with something called PIWIS and make those things inactive.
Can anyone go over it in detail?
What device do you use?
What menu do you have to go into?
What boxes do you check?
Thanks in advance
Old Jun 25, 2017 | 07:18 PM
MBA's Avatar
MBA
MBA is infamous around these parts
Hope this helps
Old Jun 25, 2017 | 08:17 PM
Duckstu's Avatar
THANKS MBA.
So helpful.
