Front Turn Signal DRL LED Queston
Old Jul 1, 2017 | 10:28 AM
tvurt's Avatar
tvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud oftvurt has much to be proud of
So I just installed a nice set of LED front DRL/Turn signals. They work great, but are currently connected to a switched lead from the fuse box - so the DRL stay on even if the headlights are on. I would like them to turn off with the headlights.
I need some sort of a relay / solenoid / switch that accepts two 12v+ with one 12v+ out. When the 2nd 12v+ activates the switch should close, turning off the DRL. I was going to tap my side marker lights for the 2nd 12v+
I have had zero luck at the local auto parts store, and don't know what term to google to buy one on line.
Thanks!
Old Jul 2, 2017 | 07:15 AM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Any common relay can be used that way.
http://www.roadkillcustoms.com/Hot-R...ay-Diagram.jpg
You can use 87 to activate with power from headlight
Or
Use 87a to deactivate with power from headlight
Old Jul 2, 2017 | 08:22 AM
tvurt's Avatar
Thanks!
Old Jul 6, 2017 | 03:29 PM
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
Subscribed since I'm considering this with my journey back to stock bumper. Please post pics with lights on and info and pricing on the parts . Thanks, Tom
Old Jul 7, 2017 | 07:15 AM
tvurt's Avatar
I went to a local car audio shop, and they got me a relay. I have not installed it yet, as I have to take the front bumper off again.....ugh.
