Plenum connectors?
Old Jul 27, 2017 | 05:58 PM
mavila's Avatar
mavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of lightmavila is a glorious beacon of light
Plenum connectors?
Can someone educate me on what the 4 connectors on the plenum are for? Wondering if it is possible to "T" into one of these to run an aftermarket boost gauge or if I would need to drill and tap into a new/separate location to do this. They look perfect for a boost gauge, but another far more experienced person actually tapped his gauge into the Y-pipe. I'd rather not modify a nice aftermarket piece if there is a simpler solution.
Old Jul 27, 2017 | 06:10 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
From driver to passenger side:
VTG controller > FPR signal > fuel vent > Brake booster.
Since I donr use vtg's anymorw I use the far left port for the BOV signal, and I've T'd into the fpr signal for a digital boost gauge/control.
Easiest way would be using a vacuum block.
Good luck
Old Jul 27, 2017 | 08:08 PM
s65e90's Avatar
s65e90 is infamous around these parts
You don't need to add anything else for a boost gauge. I'm running one teed right off the fuel pressure regulator. You can also tee into the BOV areas.
Old Jul 27, 2017 | 11:10 PM
mavila's Avatar
Interesting. Pics of the install? Where did you route the vacuum line and where did you mount the gauge?
