Will it fit?
Old Nov 21, 2017 | 11:34 AM
craigtl35's Avatar
craigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to beholdcraigtl35 is a splendid one to behold
Will it fit?
So I just purchased a new set of wheels for my .1 Turbo which I have equipped with GMG springs. What tire size would be ideal for a 20x9 +42 front and 20x12 +55 rear? I would like to run atleast a 325 section rear. Would a 255 30 fit on the front?
Old Nov 21, 2017 | 12:02 PM
Harry Da Hamster's Avatar
Harry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud ofHarry Da Hamster has much to be proud of
245/30R20 and 325/25R20
255 front is too big for a 325 rear
Old Nov 21, 2017 | 12:06 PM
craigtl35's Avatar
I guess I should clarify. Will it fit under the fender? I am trying to stay away from a stretched tire as much as possible.
Also, why would a 255 be too big for a 325 rear?
Old Nov 21, 2017 | 01:24 PM
245 should fit under your fender, it does on mine. I don't remember the offset, but they're semi aggressive with 10mm spacers, and over 2* negative camber.
If the tire width ratio is not the same at stock, people say it can cause premature wear and failure of the front diff. That's what "they say"... I don't want to be the one to test that theory though.
Old Nov 21, 2017 | 02:48 PM
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
Double and triple check all your calculations when you do non-standard wheel/tire sizes. If the front-back difference is greater than 3% you accelerate wear on the differential which is several grand to fix.
Old Nov 22, 2017 | 04:15 PM
craigtl35's Avatar
255/30/20 vs 325/25/20 looks like it will be 1.2% difference in diameter from front to back. Please correct me if I am wrong. It also keeps the front to back ratio the same as stock.
So my only question is the front width + offset with the 255 section tire.
