997.1 turbo upgrades
i have an 09 TT 6 spd turbo. I've already done the following upgrades:
Do88 intercoolers
sachs 2.5 clutch
tubi exhaust ( no cats)
1000cc injectors
do88 inlet pipes
coolant fittings pinned
Stage 3 cobb tune
car is running strong but it's time to add some more power💪🏻. Been reading allot on the forums but everything I've read is a couple years old. Was wandering what are people's thoughts on turbo upgrades. I drive 99% of the time on the street. I'm not looking for peak power just something very usable. 60-130 pulls? Is 650-700 whp attainable? My tuner reccomended the champion 68mm VTG's, and said they are hands down the best. Those are also 5 grand pluss install. Another friend of mine said to go with 63.5mm vtg's from proto. Those are about half the price but obviously smaller. Any thoughts ? I'm probably leaving some details out but would appreciate some input.
Do88 intercoolers
sachs 2.5 clutch
1000cc injectors
do88 inlet pipes
Stage 3 cobb tune
I went from the Proto 63s to the Champion 68s. Imho, it was worth the money difference because the Champion 68s on pump gas are like the Protos on racegas/e85. I have an old thread with the pbox performance comparison numbers. The biggest difference was from a roll around 75mph to about 125mph where there was a difference of about a second if I remember correctly. From 60-100mph there was a difference of 0.4s which is probably 4 car lengths.
The other thing to consider is the xona 3073 or 3076 for just a little more money. To be honest, after reading everyone else's big build projects it made me itch just a little for a bit more power. I only use pump gas so there's no point in going crazy with turbos for pumpgas and I'm trying to determine how much gain there would be for me specifically. The 68s are a really good turbo and obviously use the stock coolant and oil lines and ecu control. They are quite powerful and satisfy me pretty much 99% of the time. The 63s are also really good but since you've already put in the larger inlet pipes and injectors I would vote for the extra few grand and get the 68s. Not to be a shill, but I'm considering upgrading my Champion 68s and if you were serious then send me a PM.
Do88 intercoolers
sachs 2.5 clutch
1000cc injectors
do88 inlet pipes
Stage 3 cobb tune
Do88 intercoolers
sachs 2.5 clutch
1000cc injectors
do88 inlet pipes
Stage 3 cobb tune
- What fuel will you be running?
- Use for the car?
- Do you mind running a boost controller?
- Any potential bigger plans in the future?
- Budget?
You can hit 700AWHP with a good VTG set-up and good tuning safely depending on fuel.
any point going beyond 700hp and 650 torque to the wheels? at that point, you're in the rod bending risk territory
I have the 63s and I have data for the 68s both on e85. My 63s are at 22.5psi by 3500rpm. The 68s hit that pressure around 3800rpm. Both are plenty fast for street. I have compared my 63s to my stock turbos and it’s hard to see any difference in terms of response. They spool up like stock with a lot more top end. There is plenty of data on my build thread if you want to read thru
The 68s will flow more air at the higher engine speeds but are more money. Depends on goals. Any of these will deliver 700whp on ethanol with stock like drivability.
I should probably add based on the data I have seen from the TiAL 68s I believe you can stretch the car to 750whp on e85 on the stock engine. I don’t think anyone has done it yet but the data says yes. Jaime’s car I bet can do it. All good choices. Warning you will be hooked like all of us and want to go even bigger lol. Enjoy
In terms of real world use, with a good tune you don't notice that the power comes on a few hundred rpm higher with the 68s because the 997.1tt is geared very well for acceleration. The power in the midband is significantly better with the 68s vs the 63s on pumpgas. I didn't have e85 available for either turbo but looking at what others have achieved I think that either one is good for sub-6s 60-130mph times which is really fast. Bottom line - if you have access to e85 then save your money and get the 63s. If you are like me and have only pumpgas then I would recommend the 68s because there is stronger performance in the typical highway pull speeds (60-125mph)
Longer answer, maybe. Older Champion 68's were built with the FP/Xona HTA wheels, the newer ones are built with the FP/Xona HTZ wheels. All of Sam's stuff is HTZ aero now too.
Thanks guys. I think we have Jaime pretty close to about 750 now with some room but want it to be smooth and as safe as possible. The 68's definitely have the ability to get to 700 wheel with less effort and pushing. He will post up when we are done I am sure.
