5 bar fuel regulator need details
Old Dec 15, 2017 | 06:34 PM
wkp42's Avatar
wkp42 is infamous around these parts
So after doing a Dyno run I found out my car must have a tune. It has no bolt one but has 505 at wheels on a mustang Dyno (620+ at crank) 132 trap speed in 1/4 mile. Someone said I could easily get more power by putting a 5 bar fuel pressure regulator (if I listened properly to their wording). Is this a quick way to add HP? Are there any other little tricks that add HP like this? Is the 5 bar regulator a legit gain? Is it expensive labor to switch it out?
Old Dec 16, 2017 | 12:48 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
If you were near your fuel capacity & got a re-tune for the 5BAR (ie more boost/timing/more octane if needed etc) then yes....but by itself NO. If you even put the 5BAR in you most likely might need a new tune for the extra fuel you have now introduced to the mix, EVEN if it didn't add anymore power.
No it is not hard to install the FPR.
Old Feb 24, 2018 | 01:27 AM
Ronny-'s Avatar
Ronny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud ofRonny- has much to be proud of
I don't see how you could make those figures with the original injectors/fpr.
So i would assume either bigger injectors or a fpr are already fitted.
Should be possible to see in the tune.
So i would first start of with figuring out exactly what has been done by the previous owner.
Old Feb 24, 2018 | 09:38 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
The right way to do things is to install upgraded injectors and an upgraded fuel pump if needed.
Old Feb 24, 2018 | 10:00 AM
wkp42's Avatar
How to?
Is there a way to search with tuners by the vin?
AudiRS
Mid-Atlantic
Sep 4, 2008 11:14 AM
Q8_TwinTurbo
Oct 30, 2005 12:24 PM
