Greddy profec oled ebc
Old Sep 1, 2018 | 12:06 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
Hello,
i just purchased a 997.1tt tip with alpha tial 30/76 turbos controlled by greddy proffec oled boost controller.
usually i use HKS ebc.would you please share your greddy settings .
Actually i am running :
start 13.5psi (WG preload 14.5psi)
set 45%
gain 6
with those settings i am running a solid 18.5psi spiking to 21.5psi.
please share your settings and recommendations.
Thank you!
Ali
Old Sep 1, 2018 | 02:52 AM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Originally Posted by dynamic gt2
Hello,
set 45%
gain 6
Thank you!
Ali
Hi Ali,
I run one for a few weeks in my built 993TT with k24/18g turbos. (Cool stuff but "lighter" vs our EVC6)
This EBC let the turbos work on the wg until the "START BOOST" value, on my car wg are set 0,45(oem) and SB set at 0,8.
I noticed the later you set the SB the better is the spool.
"SET" is the boost target from the WG basis, you lower or raise the boost with it (mine is 60% on low boost and 72% on high boost).
GAIN is raising the boost target (SET) from the spool to the redline, 6% is almost flat. You can use this function to help too small turbos to keep boost at top end for example, or to map a kind of ramp up after the torque.
You speak about a 21,5 psi "spike" from 18,5:
-if the spike is before regular 18,5 a lower START BOOST value will avoid it.
-if the spike is at top end a lower GAIN will avoid it.
Cheers,
P.
Old Sep 3, 2018 | 06:58 AM
Originally Posted by K24F
Hi Ali,
Cheers,
P.
Hi Pascal,
Thank you very much for the infos.
Ali
Old Sep 3, 2018 | 07:01 AM
i would like to know what boost/set% are you running on A30/76 on 997.1tt
regards,
Ali
Old Sep 3, 2018 | 02:11 PM
K24F's Avatar
regards,
Ali
Hmm, you can't compare like that, the "SET" value you need is up to your wg pressure basis and boost target.
For example a 45% SET value with a 17psi WG will perhaps give 18,5PSI target boost, with a 10PSI WG you should need something like 65% to reach 18,5PSI.
Adjust your SET value to achieve your boost target with your setup.
(Anyway my 997.1 is not fitted with a Greedy)
BlackHorseTurbo
Apr 27, 2016 05:19 PM
John@SpeedTech
Jul 25, 2009 09:24 AM
markski@markskituning
Jul 22, 2008 04:03 PM
