997 GT2 Geo
997 GT2 Geo
Hi,
I Did my last geo from Manthey racing when the car was at the 'Ring
Today it went for wheel alignment on a hunter machine and got these confusing results.
I believe my rear suspension is failing ALSO, have uploaded pics but not clear with the wheel on
Front:
12cm Height (measured with a ruler
3*28 2*56
9*21 9*20
0*03 0*01
Back
13.5cm
2.38 2*46
0*14 0*20
0*34 -0*03
The wear was acceptable on the track but now looking for more usability for fast road driving. Slightly more aggressive than stock is ideal.
On the hunter machine there was no settings for a 09 GT2 only GT3/GT3RS 06-09 - I would pressume stock setups is fairly simmilar on the GT2?
Appreciate your input
Front:
3*28 2*56
9*21 9*20
0*03 0*01
Back
13.5cm
2.38 2*46
0*14 0*20
0*34 -0*03
This is something I had from DSC (attached the PDF also):
Porsche 997
GT3/RS/GT2
(also for all other 997 models with GT3 control arms)
STREET/OCCASIONAL TRACK
Camber
Toe per corner
Caster
Sway Bar
Front
-1.8°
+0.2mm
TPC bar 4
Rear
-2.0°
+2.0mm
TPC bar 2
HALF TRACK/HALF STREET
Camber
Toe per corner
Caster
Sway Bar
Front
-2.5°
-0.3mm
TPC bar 3
Rear
-2.0°
+2.0mm
TPC bar 2
¾ TRACK/OCCASIONAL STREET
Camber
Toe per corner
Caster
Sway Bar
Front
-2.7°
-0.7mm
TPC bar 3
Rear
-2.2°
+2.0mm
TPC bar 2
FULL TRACK SETUP
Camber
Toe per corner
Caster
Sway Bar
Front
-3.0°
-1.0mm
TPC bar 3
Rear
-2.4°
+2.0mm
TPC bar 3*
*Only with motorsport differential setup
Not sure if it hels or not.
Ed
Porsche 997
GT3/RS/GT2
Camber
Toe per corner
Caster
Sway Bar
Front
-1.8°
+0.2mm
TPC bar 4
Rear
-2.0°
+2.0mm
TPC bar 2
Camber
Toe per corner
Caster
Sway Bar
Front
-2.5°
-0.3mm
TPC bar 3
Rear
-2.0°
+2.0mm
TPC bar 2
Camber
Toe per corner
Caster
Sway Bar
Front
-2.7°
-0.7mm
TPC bar 3
Rear
-2.2°
+2.0mm
TPC bar 2
FULL TRACK SETUP
Camber
Toe per corner
Caster
Sway Bar
Front
-3.0°
-1.0mm
TPC bar 3
Rear
-2.4°
+2.0mm
TPC bar 3*
Ed
