Brake Fluid Flush
Old May 22, 2019 | 02:36 AM
997tt_'s Avatar
997tt_ is infamous around these parts
Brake Fluid Flush
Hi Guys,
i want to flush my brake fluid.
The preowner used Ap Racing 600, but i want to use a normal DOT 4.
Normally i flush without piwis, but in this case i think everything of the old should be removed, so how is the procedere for that?
I use this tool for flushing:
https://www.gl-gmbh.de/catalog/product/view/id/294716
Old May 22, 2019 | 09:18 AM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
You really need the piwis to bleed the ABS module, if you dont introduce any bubbles/let the res go dry when you chamge the fluid it wont be necessary.
Service manual calls for draining 250ml from each corner for a fluid change, if you want to be extra sure you flushed out all of the old fluid just flush larger amounts maybe 700ml-1L from each corner.
Good luck
SRW
Jan 23, 2010 08:50 AM
ryem3
Jan 19, 2010 05:15 AM
ryem3
Jul 6, 2009 09:53 AM
ttgangsta
May 25, 2006 10:39 AM
shrews
May 5, 2004 09:18 AM
