New member needs info on LSD and rocker panel pt option
Originally Posted by atomic80
There's an additional option code for painting the front and/or the rear separately. In addition to that, there's another code to have the whole thing painted including the front grille. I like having choices.
codes for painting
found only the code to paint car color under door -XAJ
Reason I didn't order the option. Couldn't find any option
to paint front and rear portions. Thought the turbo
looks best consistently back accross the entire bottom
of the car.
of the car.
CNE - front lip painted $590 (I personally wouldn't do this one because this gets scraped so often)
CNF - front air intakes painted $990 (IMHO, looks odd with these painted)
CNG - Lower part of rear apron painted $590
DAJ - Exterior package painted - $1,990
atomic 80...the steering wheel with large spokes is most likely
XPA. Correct? Then CPA (had to have 431/459) must be this same wheel as XPA but with the CD/radio controls and cross stitching? Would you agree with this interpretation?
The wide spoke steering wheel photo you posted'
is that not XPA option (thicker 3-spoke steering
wheel in smooth leather)???
If that is true, what I was asking is that option
CPA (thicker 3-spoke/multifctn whl with cross stitched
seam) should be the same wheel as XPA (hopefully),
but with multifunct and cross stitching added on???
Ok...
You would need option 431 which is the 3 spoke steering wheel multifunction but that comes with the thinner spokes. If you wanted to get the thicker spokes then you'd have to add option CPA. 459 is just adding leather to the steering wheel at no extra charge. So to sum things up, go with 431, 459 and CPA.
Exactly what I ordered, now is the CPA/431/459 the same wheel
you posted a picture off (larger spoke photo with grey leather) except the CPA/431/459
has multifunction added to it plus cross stitching????thank, john
Jul 29, 2019 11:13 AM
