World Premiere at Essen Show 2006 - Press Kit: New TechArt kit for 997TT
SubscribePorsche 911 Turbo (997) with TechArt Tuning
Technical Specs
Engine:
Watercooled six-cylinder boxer twin-turbo engine with TechArt performance tuning consisting of 2 special turbochargers with variable turbine geometry, sports air filter, TechArt stainless steel high performance exhaust system with special manifolds and steel-bed high performance catalysts and
a recalibrated ECU. TechArt engine design package.
Displacement 3,600 cm³
Bore x stroke 100 x 76.4 mm
Max. power 580 hp / 427 kW at 6,000 rpm
Max. torque 700 Nm at 4,850 rpm (from 3,200 – 6,000 rpm permanently
more than 670 Nm)
Compression-ratio 9.0:1
Max. boost 1.2 bar
Max. revs 7,100 rpm
Power output per liter 161.11 hp per liter capacity
Transmission:
Permanent four-wheel drive
Six-speed manual gearbox with modified transmission-ratios in 5th and 6th speed, TechArt gearshift
travel shortage and additional gearbox-oil cooling
Gear ratios::
1st speed 3.82
2nd speed 2.14
3rd speed 1.48
4th speed 1.18
5th speed 0.92
6th speed 0.75
Axle ratio 3.44
Chassis:
TechArt VarioPlus coil-over sport suspension
Wheels:
TechArt Formula light alloy wheels, one-piece, 8.5Jx20 in front with 245/30 R 20
ContiSportContact3 tires, 12Jx20 in rear with 325/25 R 20 tires.
Brakes:
Standard Porsche Ceramic Composite Brake
Front: 380 mm discs and 6-pot aluminium Monobloc fixed calipers
Rear: 350 mm discs and 4-pot aluminium Monobloc fixed calipers
Bodywork:
2+2 seater coupe with TechArt bodystyling kit I, consisting of: front spoiler I, side skirts, side mirror
moldings, rear spoiler I, roof spoiler, rear diffuser, headlight moldings
Length 4,450 mm
Width 1,852 mm
Height 1,300 mm
Wheel-base 2,350 mm
Tank capacity 67 liters
Curb weight 1,592 kg
Weight/power ratio 2.74 kg / hp
Performances:
Acceleration: 0 – 100 km/h: 3.46 s
Maximum speed: 339 km/h
Retail price: about 200,000 Euros
Manufacturer:
TechArt Automobildesign GmbH, Röntgenstrasse 47, D-71229 Leonberg-Höfingen, Germany, Tel: +49 / (0) 71 52 / 93 39-0, Fax: +49 / (0) 71 52 / 93 39 33, Internet: www.techart.de
Info and pictures - courtesy of gesi999 aka Jan from TechArt.
Technical Specs
Engine:
more than 670 Nm)
Max. boost 1.2 bar
Max. revs 7,100 rpm
Transmission:
Gear ratios::
1st speed 3.82
2nd speed 2.14
3rd speed 1.48
4th speed 1.18
5th speed 0.92
6th speed 0.75
Axle ratio 3.44
Chassis:
Wheels:
Brakes:
Bodywork:
Length 4,450 mm
Width 1,852 mm
Height 1,300 mm
Wheel-base 2,350 mm
Performances:
Manufacturer:
