Blacked out TT...........
Old Dec 23, 2006 | 04:57 PM
  #31
micah's Avatar
micah has a spectacular aura aboutmicah has a spectacular aura aboutmicah has a spectacular aura about
Originally Posted by phantasms
I hate blacked out cars.
yes gene lol
edit: Lou, love ur car, looks great
Old Dec 23, 2006 | 05:19 PM
  #32
MattM's Avatar
MattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud ofMattM has much to be proud of
wow that looks nice ... so stealth.
Old Dec 23, 2006 | 10:45 PM
  #33
iLLM3's Avatar
That Z06 looks AMAZING, love it all blacked out! That car is in NY correct?
Old Dec 23, 2006 | 11:17 PM
  #34
NeunElf's Avatar
NeunElf is infamous around these parts
Thumbs up
I normally don't go for Vette's, but that is one super sharp ride!
Old Dec 25, 2006 | 11:11 AM
  #35
micah's Avatar
yUp .....
Old Dec 26, 2006 | 03:13 AM
  #36
habitat's Avatar
Senior Member
habitat is just really nicehabitat is just really nicehabitat is just really nicehabitat is just really nice
Love the blacked out look. Just a pain to keep clean.
Old Dec 26, 2006 | 02:24 PM
  #37
iLLM3's Avatar
Originally Posted by micah
yUp .....
Who is he and is he on here? I would love to meet up with him! i have seen him driving around on Jericho Tpk a few times
Old Dec 26, 2006 | 03:40 PM
  #38
DJ's Avatar
DJ
that blacked out z06 is stunning!
Old Dec 26, 2006 | 04:29 PM
  #39
jiaim's Avatar
jiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to alljiaim is a name known to all
yep , nice vette, hope the engine goes with the look
Old Dec 26, 2006 | 04:40 PM
  #40
iLLM3's Avatar
Im sure you know, but that is a regular C6 and a diff motor than the Z06
Old Dec 26, 2006 | 04:51 PM
  #41
jiaim's Avatar
yep but an aps tt can be fitted to z06
peter (from aps on corvette forums ):
I think it's too early to say that the stock comp ratio is too high for forced induction at relatively low boost pressure, I think the ZO6 would make awesome torque and power at even 5 PSI boost (with the large turbochargers and effcient intercooling) with a safe/correct ignition timing and air fuel ratio strategy.
APS is developing a specfic intercooled twin turbo system to suit the Z06, Time and more testing will prove this one way or the other.
I think a large twin screw would be awesome though I doubt there's a large enough twin screw available to support the mass air flow required for a 427 cube engine (you require huge mass air flow to produce around 650 to 700 whp at 6 - 7 PSI), a pair of 60 lb per minute turbochargers would be ideal on the ZO6 engine and would easily generate around 700 whp at low boost, 6 to 7 PSI, all good.
The ZO6 twin turbo system will be absolutely awesome, with highly efficient air to air intercooling I believe that the stock ZO6 twin turbo engine will produce at least another 200 whp very comfortably on 93 octane fuel at very low boost pressure, all good.The Z06 kit should be very similar to the C6 kit. Probably just a change in the shape of the exhaust ports on the cast manifolds. Other than that, the engines are physically the same on the exterior as an LS2 engine.The stock LS2 engine with APS twin turbos will generate around 550 whp at 5 to 6 PSI tuned for 93 octane fuel with a free flowing 3'' exhaust exhaust on a dyno jet - the peak power is important though the power under the curve tells the real story on the street.
too bad aps'swebsite is down now : http://www.airpowersystems.com.au/
Old Dec 26, 2006 | 11:01 PM
  #42
iLLM3's Avatar
Interesting info, thanks! BUT, that still is all speculation, unless they have done it right?
Old Dec 27, 2006 | 04:18 AM
  #43
jiaim's Avatar
Aps makes top notch quality turbo kits (subaru , 350z/g35, corvette c6 & c5) all plug and play
(6lbs of boost) = http://forums.corvetteforum.com/show....php?t=1574824
Old Dec 27, 2006 | 09:57 PM
  #44
iLLM3's Avatar
I know all about them haha, i was just saying about the Z06 specifically, i mean the Z06 and regular C6 are VERY diff motor wise, i just thought they were speculating on how it will run, ah well. Im sure we will start seeing some kits come out shortly and insane numbers
Old Dec 28, 2006 | 06:31 AM
  #45
jiaim's Avatar
You may be right, don't know very much about those cars, sure a TT z06 will be a tire killer
