When you start you engine when its cold
Old Apr 5, 2007 | 11:55 PM
335_II's Avatar
335_II is infamous around these parts
Sometimes when i start my engine for the first time of the day it revs to about 2500-2800 and then slowly comes down...anyone elses car do this?
Old Apr 6, 2007 | 12:15 AM
N2it's Avatar
N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !N2it Is a GOD !
Exactly the same!
Old Apr 6, 2007 | 07:11 AM
MeanMachine's Avatar
Its common on all of the Porsche's 911, Boxster, Cayman etc, I noticed that other cars such as Mercedes-Benz or Jaguar take slightly less time to get warm.
Old Apr 6, 2007 | 07:21 AM
Dan98's Avatar
Dan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud ofDan98 has much to be proud of
my old Lincoln used to do the same...
Old Apr 6, 2007 | 07:51 AM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
The engine management system is programming for cold starts, (programmed in all aspects), since the motor is cold and its not up to running temperature the fuel isn't being burned that efficiently yet, in order to keep it running the EMS compensates by making the fuel mixture significantly richer, how rich? Well that all depends on the model of the car and how the cold start was programmed. Also someone can correct me if I'm wrong but the throttle is opened at a slightly higher percentage as well. Also a benefit of the car being so rich during start is that it warms up the engine quicker as opposed to having a normal a/f ratio (being leaner).
*Disclaimer* this is what I've come to understand and read, I could be wrong its been a while since I've read the book.
Old Apr 6, 2007 | 10:07 AM
335_II's Avatar
soime of my other cars do this but do not rev nearly as high....
Old Apr 6, 2007 | 10:18 AM
Every motor is different.
Old Apr 6, 2007 | 10:35 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I think part of the noise may also be the air injection pump which helps light up the cats to efficiency
Old Apr 9, 2007 | 04:38 PM
mishref's Avatar
mishref is infamous around these parts
I have heard it heats the cats; once the rpm drops .. your good to go.
Old Apr 9, 2007 | 09:22 PM
crd's Avatar
crd
crd is infamous around these parts
My car did this only once, in 6 mos. of ownership, most of which was in relatively cold weather. I don't think it's a problem unless it happens during the warmer months.
Jul 29, 2019 11:13 AM
Jun 10, 2017 07:45 PM
vr6tee
Aug 29, 2015 03:52 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
