Question about wheel spacers
Old Jun 22, 2007 | 07:35 PM
ldye's Avatar
ldye is infamous around these parts
I'm helping a friend with a spacer question. He ordered 17mm spacers from Porsche and only got the rears. Should the fronts have been ordered also? We were thinking they would be set of four.
Old Jun 22, 2007 | 07:39 PM
damon@tirerack's Avatar
Moderator
Almost always spacers are ordered by pairs only. Unless he specified he wanted all four, he should not have expected them. I always assume they are wanted by the pair unless told otherwise.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jun 22, 2007 | 11:57 PM
rockamoto's Avatar
rockamoto is infamous around these parts
Hmm.. I spoke to my dealer about these as well. They recommended 5mm rear only. So far I plan on keeping my wheels so I wanted them to get lined up closer to the edge of the fender. Do the spacers require new aligment settings and will they effect handling?
Old Jun 23, 2007 | 07:14 AM
jhbrennan's Avatar
Spacers are used to compensate for offset differences in various wheels. For example the offsets for the front wheels on the C2 and C4 are usually the same. On the rear since the C4 is a "widebody" many wheels designed for the narrowbody C2 need spacers to push them out if they are going to be used on the C4. The Sport Design 19" Porsche wheel only comes in one offset for the rear - 67mm which is fine for a C2. You can use it on the C4 but with 17mm spacers to effectively get to the C4 stock offset of 51mm.
Old Jun 23, 2007 | 08:16 AM
atomic80's Avatar
I definitely DON'T recommend getting spacers larger than 5mm. I had 18mm spacers on mine with the GT3 wheels originally. It affected the handling characteristics of the car in such a way that the car suddenly felt a bit "loose" at the handling limits. I eventually ended up selling the GT3 rears for the GT3 RS rears which didn't need those spacers and suddenly the car felt much more planted. So, bottom line is, I DON'T recommend getting those spacers. Go with wheels with the proper offset instead.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
