Rear Tire Size 325/30/19?
Old Jul 30, 2007 | 06:08 PM
BlackBear's Avatar
BlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud ofBlackBear has much to be proud of
The 997 GT2 uses 325/30/19 rears with 235/35/19 fronts.
If the GT2 uses the same ABS/PASM computers as the Turbo we should be able to run 325s on a Turbo as well.
Tirerack does not list a Porsche approved tire in this size yet. Even the Michelin website does not list one yet.
I think that this will change with the introduction of the GT2. When is it coming?
The diameter of the 305 tire is 26.3", the 325 tire is 26.7". Should this be a deviation within the tolerance allowed?
Old Jul 30, 2007 | 11:13 PM
atomic80's Avatar
Those tires are Michellin Sport Cup tires. That's why you're not able to find those in PS2 trim.
Old Jul 31, 2007 | 06:29 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
I wouldn't do it. The Gt2 has no 4wd differential. The TT does, and it is quite sensitive to variations. If you increase the height of the rear tire, you would have to increase the front proportionally and you should be ok
Old Jul 31, 2007 | 07:02 AM
TT Surgeon's Avatar
I believe the rear are 305-30-19 stock, so you should be OK. Keep in mind the GT2 uses different wheels with 12" width. They look like RS wheels but they are unique to the '2' I believe. But agree with Lou, try and stay within spec with the supersensitive awd system.
Old Jul 31, 2007 | 10:48 AM
PbPedis's Avatar
PbPedis is infamous around these parts
I remember someone posting here or on another site that they went up one size to 315's and it totally threw off the handling. They recommended against it.
Old Jul 31, 2007 | 11:59 AM
Mike2727's Avatar
Mike2727 is infamous around these parts
You can go without a problem to 325 on 20's
Mike
Old Jul 31, 2007 | 01:32 PM
Paris_CarreraS's Avatar
Paris_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the rough
I think maybe 325 will fit...but you have to change your front tire size because of the 4WD system.....
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
gulf gt
Aug 27, 2015 10:27 AM
ModBargains
Aug 20, 2015 12:28 PM
Aug 19, 2015 06:35 PM
