NEW Product - Agency Power Sway Bars Preorder 20% OFF
Vivid Racing's Porsche 997 Turbo had the opportunity to test the new adjustable sway bars by Agency Power. The front sway bar is 25mm and 3 way adjustable. The rear sway bar is 24mm and 3 way adjustable. The bars are a solid construction and include proper bushings for mounting. The sway bars do work with the stock sway bar links. However Agency Power has an upgraded front sway bar link and rear unit for the 997TT soon to be released. The sway bars are slightly larger then what is currently on the market. The adjustability and increased diameter provides you the ability to dial in your sway bars for a balanced handling car. The larger rear diameter sway bar helps tremendously improve the cars natural habit to have understeer. The front sway bar allows you to balance out the oversteer and keep the car more neutral if desired.
The sway bars will be available in a white powdercoat and should be available for sale Feb 1, 2009. Right now we are taking preorders with a 50% deposit for them at a discounted price.
View more pics of our Project 997TT here - http://www.vividracing.com/forums/gallery/browseimages.php?c=342
Pricing will be for 6speed members who preorder prior to Feb 1:
Agency Power Front 25mm Adjustable Sway Bar - $240 (Retail $300)
Agency Power Rear 24mm Adjustable Sway Bar - $200 (Retail $250)
Here are the Prototype Pictures
Well the Agency Power brand is our own. I love GMG and those guys. But we have been doing sways for a while, see www.agency-power.com, and finally got our prototype ones done. GMG does not say the exact diameters, but ours are 25mm front and 24mm rear. Both bars are 3 way adjustable and both are solid. So really, there is not much difference.
PS yours shipped out yesterday so should be with you first part of next week
These are now instock ready to ship. Under $300 on the front and under $250 on the rear sway bar. Both are 3 way adjustable!
Product Info
In the quest to create the most well balanced suspension for the 997 Turbo, Agency Power has developed these sway bars to our specifications. The all wheel drive Porsche turbo cars naturally have a lot of under steer. Under steer is when you take a turn but your car keeps going outwards. With an AWD car, getting the rear end around can be easily done with a larger sway bar. However you do not want to induce to much over steer as then you will be throttle steering or sent into a drift. With the combination of a properly balanced front and rear sway bar, your car will handle turns much more neutrally and quickly. The sway bars are designed to stiffen up the chassis as well to reduce body roll. Some times called “anti roll bars”; sway bars help keep the chassis flat through the turns. In combination with a good set of springs or coilovers, you will greatly improve your handling of your Porsche 997 Turbo.
The Agency Power sway bars are made in the USA from high strength steel. The adjustability holes have been engineered to not overload the sway bar links causing them to break. The solid sway bars feature 3 way adjustable ends for maximum adjustability for under and over steer. All of our sway bars feature urethane bushings to fit in the stock bracket for an OEM fit. The sway bars are finished in a white powder coat like our other sway bars to stand out in front of the competition. The rear bar is a 24mm 3 way adjustable unit which is a very complex design featuring 12 bends. These sway bars are over 50% stiffer then stock. Perfect design and setup for those wanting a great handling street car with high speed track performance. Sway bars are sold individually.
You can read more about the sway bars here - http://www.vividracing.com/catalog/s...&filter_id=135
Front Bar
Rear Bar
Product Info
Front Bar
Rear Bar
Jul 29, 2019 11:13 AM
r_matt_6
Oct 8, 2015 06:07 PM
drinaldis
Sep 28, 2015 01:37 PM
