Evolution Motorsports 997.1TT Engine Performance Systems
Industry leaders since the release of the 997 Turbo in 2007 and holders of numerous world records for the quickest and fastest watercooled Porsche Turbos, Evolution Motorsports offers a range of bolt-on packages for stock engine 997.1TTs that will turn a quick GT cruiser into a true supercar on the street and track.
Developed, tested, and refined over years of use and abuse on our own cars, these Engine Performance Systems have been meticulously engineered to deliver the highest levels of performance without sacrificing reliability or everyday usability. As performance systems, these kits pair EVOMSit software with quality EVOMS-designed and built hardware, with a specific tune made to match each set of components. This ensures the software and hardware work in harmony together, and allows us to focus on developing each system so that power, reliability, and driveability are consistent across every part of our product line. The systems are structured to maximize value and allow for easy upgrades without having to buy anything twice.
EVOMSit Software Features
IST (Intelligent Switching Technology™):
IST is an OEM feature that is built into the factory ECU and allows for automatic switching of ignition timing maps based upon input received from other engine sensors. Available for certain EVOMSit performance programs, the EVOMSit IST programming incorporates this intelligence for true and safe flexible power without compromise. The EVOMSit ECU tuning utilizes the multiple OEM ignition tables that are progressively staged and we modify them to our performance specifications, which can optimize safe performance based upon outside conditions and different octane fuels. The ECU automatically switches to the best-suited ignition map creating an automatic “race mode” if race fuel is utilized. This IST function is always active and will switch automatically without having to make any physical changes. IST is far more intelligent than any manual switcher found on the market. The use of manual switchers can cause serious engine damage if accidentally switched to a “race mode” without having adequate octane levels in the car. This manual type of switching technology physically locks the timing map and can over ride the ECU’s ability to protect itself if unfavorable conditions arise. This manual switching is archaic considering that OEM ECU has the ability to analyze conditions and switch timing maps automatically. EVOMSit with IST is the intelligent way to utilize ECU timing map switching.
SP (Sport Pedal™):
All E-Gas (drive by wire) cars from model year 2000 and newer have an electronic throttle valve, which is controlled by the cars ECU. Available in certain EVOMSit performance programs, EVOMSit Sport Pedal™ (SP) feature changes the ratio of accelerator pedal movement verses opening of the throttle valve which will increase throttle response. By modifying these maps in the ECU calibration, throttle response is drastically improved and the “throttle delay” which is a common complaint among enthusiasts is eliminated.
For more information to purchase, visit www.evoms.com, email us at info@evoms.com, or call +1-480-317-9911.
EVT550/570R Package - 552hp, 544ft-lb on Pump Gas - $2795
Package Includes:
- EVOMSit Software
- EVOMS Boost Recirculation Valves (Currently under redevelopment for availability Fall 2014)
- EVOMS GT Spec Denso Double Platinum Spark Plugs
- 0-60: 3.6sec*
- 0-100: 8.2sec*
- 1/4mi: 11.97sec @ 122.3mph*
- Standing Mile: 173mph*
EVT580/600R Package - 581hp, 566ft-lb on Pump Gas - From $3295
Package Includes:
- EVOMSit Software
- An exhaust is required to make advertised power, see website for options
- 0-60: 3.5sec*
- 0-100: 7.5sec*
- 1/4mi: 11.40sec @ 124.1mph*
- Standing Mile: 180mph*
EVT600/620R Package - 603hp, 586ft-lb on Pump Gas - From $6349
Package Includes:
- EVOMSit Software
- EVOMS Clubsport Exhaust Manifolds
- 0-60: 3.2sec*
- 0-100: 7.2sec*
- 1/4mi: 11.25sec @ 125.5mph*
- Standing Mile: 183mph*
EVT620/650R Package - 624hp, 602ft-lb on Pump Gas - From $9295
Package Includes:
- EVOMSit Software
- EVOMS Clubsport Intercoolers and Silicone Boost Hoses
- 0-60: 3.1sec*
- 0-100: 7.0sec*
- 1/4mi: 10.97sec @ 127.7mph*
- Standing Mile: 185mph*
EVT650/670R Package - 647hp, 670ft-lb on Pump Gas - From $9295
Package Includes:
- EVOMSit Software
- EVOMS High Flow Turbo Inlet Ducts
- 0-60: 3.0sec*
- 0-100: 6.9sec*
- 1/4mi: 10.97sec @ 127.8mph* (as tested on '09 997TT Tip Cab, other cars are 6MT Coupes)
- Standing Mile: 187mph*
Signature EVT Turbo Kits
EVT700/720R Package - 708hp, 695ft-lb on Pump Gas - From $14895
Package Includes:
- EVOMSit Software
- EVOMS 65mm Billet VTG Turbocharger Upgrade
- An upgraded clutch (manual transmission) or TCU upgrade (Tiptronic transmission) is required, see website for options
- 0-60: 2.9sec*
- 0-100: 6.8sec*
- 1/4mi: 10.71sec @ 138mph*
- Standing Mile: 192mph*
EVT720/750R Package - 722hp, 719ft-lb on Pump Gas - From $15995
Package Includes:
- EVOMSit Software
- IPD Competition Intake Plenum and OEM 82mm GT3 Throttle Body
- 0-60: 2.9sec
- 0-100: 6.7sec
- Standing Mile: 193mph
EVT750/775R Package - 773hp, 769ft-lb on 93 Octane - From $17395
Package Includes:
- EVOMSit Software
- EVOMS Lightweight Underdrive Crank Pulley
- EVOMS HED Ignition Coil Set
- 0-60: 2.8sec*
- 0-100: 6.5sec*
- 1/4mi: 9.70sec @ 148.5mph* (Recorded on drag radials)
- Standing Mile: 198mph*
Evolution MotorSports | www.evoms.com
EVOMSit - intelligent tuning |www.evomsit.com
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
Home of the Worlds Fastest 997TT Porsche(s)
997TT Standing Mile = 234.6 MPH
997TT Standing 1/2 Mile = 217.09 MPH
Fastest 1/4 Mile = 9.29 @ 172.7 MPH
60-130 MPH Time = 3.28 Seconds
P: 480.317.9911
F: 480.317.9901
E: info@evoms.com
04-28-2022 12:38 AM
GTstreet996
10
09-26-2015 01:03 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
