All products are custom made to order, nothing stocked on the shelves as we specialize in accommodating the shank lengths to the dimensions needed when Porsche owners are running wheel spacers.
Call us today for your direct OEM replacement! #welugwheels
All our titanium products are custom made to order and in doing so we perfectly paired up our 2-pce titanium Porsche lug bolts with a set of MORR Wheels MS11's Contoured | Brushed Lips w/ Gloss Clear, Brushed Centers w/ Candy Black Clear, Custom Machined Porsche Center Caps.
Order a set of MORR Wheels and TiKORE titanium lugs today. E-mail CFallon@tikore.com
All our precision titanium TiKORE titanium lugs are custom made in house here at our facility. We only use aerospace certified grade 5 6L-4V titanium. Certified means each batch of material is tested to ensure the mechanical properties are correct. (not china titanium)
All lug bolt threads are rolled, not cut, for superior strength and wear resistance.
Titanium has an extremely high resistance to corrosion.
Here we have more customer submitted photos of his 911 turbo portaying why our titanium lugs are referred to as pure automotive jewelry
*We specialize in custom lengths over OEM for those running wheel spacers. We accommodate the shank length tho the dimensions needed so you get the proper thread engagement when adding spacers.
We always appreciate customer submitted photos, especially when they had a photo shoot done after installing the last finishing details...our TiKORE titanium lug bolts.
Vehicle: 2014 Porsche 911 C2S
Product: TiKORE Porsche 2-piece titanium lug bolt set
Wheels: Satin Bronze HRE S107s
Thread: M14x1.5
Seat: Ball
Shank Length: Standard 28mm
Finish: Bright Machined titanium
Weight per bolt: .15 lbs
Photo Credit:
Alex Stone
702.353.4110
fotosbyalex.com
Any questions on ordering contact CFallon@tikore.com or call the TiKORE facility at 954-616-5902.
All our precision products are designed and CNC machined in house here at our TiKORE facility. We use aerospace certified grade 5 6AL-4V titanium material. By certified we mean each batch of material is tested to ensure the mechanical properties are correct. (no Chinese parts)
New wheels, no problem! Our customer got a new set of Forgeline wheels for his Porsche. The great benefit is that our TiKORE titanium lug bolts get new shoes to be sported with!
*Also remember before trading in your car equipped with TiKORE lugs to remove them and swap with OEM lug bolts. Our lugs hold their value and can be used on similar models!
Any questions on ordering/fitment contact CFallon@tikore.com or call the TiKORE facility at 954-616-5902.
Always glad to see our precision titanium lug bolts designed and CNC machined in house here at TiKORE, being bolted on globally! Here we have our International customer who submitted photos from Dubai of his Porsche 911 Carrera sporting our TiKORE 2-piece titanium Porsche lug bolts with his Vorsteiner wheels.
If there was a Porsche center fold section, these customer submitted pictures would be published without a doubt! Here is a great build thread that we are glad to be a part of and would like to share with the rest of you.
TiKORE 2-piece Porsche titanium lug bolts equipped on this new Porsche 991 sporting Vorsteiner VSC-101 Wheels.
Designed and CNC machined in house at our TiKORE facility out of aerospace certified grade 5 6AL-4V titanium. By certified we mean that each batch of material is tested to ensure the mechanical properties. All threads are rolled and not cut for superior strength and wear resistance.
TiKORE Tuesday, where a local 997.1 turbo Porsche customer showed up for his install of a matte titanium 2-piece Porsche TiKORE titanium lug bolt set.
The customer had an immaculate Porsche sporting a set of HRE wheels, however that were bolted on by a set of corroded OEM lugs that physically were seized to the wheels...and had to be replaced.
TiKORE machines in house out of an aerospace certified grade 5 6AL-4V titanium. Certified means each batch of material is tested to ensure the mechanical properties are correct. Each lug is manufactured individually to strict tolerances and all threads are rolled not cut for superior strength and wear-resistance.
Now for the install photos.
...and we had to take some with the TiKORE 997.1 turbo shop car
