997 Vendor Classifieds
Elite Motorsports | Shifter & E-Brake Riser Kit
Old Sep 8, 2015 | 08:03 AM
Kai@ELITEMS's Avatar
Kai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant futureKai@ELITEMS has a brilliant future
This setup raises the shifter as well as the e-brake assembly by 1.5"(38mm) closer to the steering wheel on all 986-987-996-997 models.
In doing so bringing the shift **** to be closer to the steering wheel and quickens inputs when changing gears.
Installation is straight forward with the kit mounting to the factory locations.
We came up with this setup on our shop Spec Boxster after going with other options out in the market currently. This only raised the shifter but we saw it put too much stress on the shift lines because it only raised the shifter assembly only. Upon raising the e brake handle with same spacers we can now shift much smoother with the lines not being under stress during shifting both being raised 1.5".
Can not the used with the center console in place must be removed unless modified*
Price : $74.95 shipped
Purchase Here : http://shop.elitemotorsport.net/Elit...ShifterKit.htm
Old Nov 25, 2015 | 06:32 AM
10% off w/ mention of Black Friday sale!
Jul 29, 2019 11:13 AM
