Why Does the Carrera S "Rattle" When Starting Cold?
Old May 8, 2008 | 03:09 PM
abe911's Avatar
abe911 is infamous around these parts
I remember looking this up either on these site or Rennlist. It did have something to do with a pump or vaulve on start up and it is normal. I look at it as something similar to us when you wake up in the morning and clear your throat.
abe
Old May 8, 2008 | 07:26 PM
Bratman's Avatar
Bratman is infamous around these parts
Mine does it too, but I'm quite certain it's either normal or the majority of the 3.8L cars suffer from this problem. I happened to be hanging around the Porsche dealership one morning as I was waiting for my oil change to be completed and, for whatever reason, they were moving a bunch of their cars around the lot. They were starting them cold and I could clearly hear the 3.8L S cars making the same/similar noise. Most if not all the cars were brand new, demos or lightly used 997s and all sounded the same/similar. I stopped worrying about mine after that day...
Old Sep 22, 2011 | 12:23 AM
socalbd's Avatar
socalbd has a spectacular aura aboutsocalbd has a spectacular aura about
Same thing with my 2008 2S. 20K miles.
Old Sep 22, 2011 | 04:48 AM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
If you are referring to the popping noise that goes away in a few minutes, it is due to an emissions cycle. The ignition timing is retarded and the air pump is acitvated to heat up the converters to minimize the increased exhaust emissions from a cold startup. If it is a buzzing or high pitched rattle, it is likely a heat shield or exhaust system component.
Old Sep 22, 2011 | 10:53 AM
mousecrab's Avatar
mousecrab is infamous around these parts
Same here 2006 C2S. I just use that 2 min or so to warm up my car.
Old Sep 23, 2011 | 09:24 PM
muerdeme's Avatar
muerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to allmuerdeme is a name known to all
When I start my C2S up, I don't hear any popping or rattling in the exhaust. The exhaust sounds as connected to the frame as ever, but the note does tend to "burble" for about a minute (sorry for the techical term).
Old Sep 24, 2011 | 01:23 PM
911cv's Avatar
911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold911cv is a splendid one to behold
My '07 C2 does it too. It goes away after about 20-30 seconds.
Jun 10, 2017 07:45 PM
riverflyer
Sep 1, 2015 04:22 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
