Tires from Tirerack with TPMS
Old May 22, 2008 | 09:51 PM
rah79's Avatar
rah79 is infamous around these parts
OK so I bought 4 tires from tires from tirerack and I chose the Vehicle, Make, Model, Year, and chose the with TPMS option. So my question is does it come installed inside the tires, separate in the box, or do I have to buy them separate?
Thanks.
Old May 22, 2008 | 09:55 PM
b911s's Avatar
b911s is infamous around these parts
their seperate, they install on your rims. But does your car have TPMS from the factory? if it does then they are already on your wheels.
Old May 22, 2008 | 10:01 PM
rah79's Avatar
Yes, I have TPMS on the car(factory). So I can for the moment take them out from my factory wheels and install them in the new one?
TIA
Raj
Old May 22, 2008 | 10:07 PM
b911s's Avatar
TIA
Raj
I would think you could. May want to ask your dealer to make sure.
Old May 22, 2008 | 11:11 PM
NorthVan's Avatar
TIA
Raj
yes you can, but you can also buy a second set on sensors for your new wheels.
Old May 22, 2008 | 11:16 PM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Thanks for the info!
Old May 23, 2008 | 06:21 AM
jhbrennan's Avatar
Thanks.
Sounds like you just bought the tires (not any wheels) so you don't need new TPMS sensors, assuming your car already has TPMS. You just need to mount the new tires. Make sure the installer doesn't try to sell you new valve stems and tell them to be careful of the TPMS inside the rim.
Old May 23, 2008 | 12:13 PM
GraSox's Avatar
GraSox is infamous around these parts
Does anyone know if I can add the TPMS? I bought mine used and would like to have it.
Thanks for the help!
Old May 23, 2008 | 12:18 PM
OC Pcar's Avatar
OC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant futureOC Pcar has a brilliant future
you can't add the factory TPMS but you can add aftermarket
Old May 23, 2008 | 12:34 PM
GraSox's Avatar
Who has after market TPMS? Are they any good?
Anyone done it?
Old May 23, 2008 | 01:48 PM
damon@tirerack's Avatar
Moderator
We do that for wheel sales. If the car has TPMS we need to know if we need to add sensors to wheel packages before the tires go on. Also, if your car has TPMS you have the option of buying runflat tires.
Only a handful of companies make the TPMS sensors, so most all of what we sell is the same as OE.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old May 23, 2008 | 02:45 PM
GraSox's Avatar
I have a 997 w/o the factory TPMS and wanted to know if it can be added as a after market thing.
Thanks!
Old May 23, 2008 | 02:48 PM
larrytrk's Avatar
larrytrk is infamous around these parts
What runflat tires are recommended for an 06 997S with classic 19"s?
Old May 23, 2008 | 02:57 PM
jhbrennan's Avatar
I'd be interested too - I wasn't sure anyone was making runflats in the sizes we need. Runflats would be great for roadtrips.
Old May 23, 2008 | 03:11 PM
GraSox's Avatar
Actually i don't have run flats.....I just wanted the TPMS to catch when the tire goes flat quicker so it doesn't ruin the side wall.
