HELP, Gundo Hacked my Exhaust now i get a Check Engine Light!
Old Sep 24, 2008 | 08:32 PM
larry_chip's Avatar
larry_chip is infamous around these parts
first i had the fabspeed bypass pipes on for like 2 months, they we're too loud so i went with the gundo hack mod on my stock pipes, now i get a Check Engine Light,
i have that hand held thingy that can reset check engine lights, i reset it twice so far but she keeps coming back, its saying its a
EVAP Control Emissions Leak (large)
please let me know if anyone else had this problem.
Old Sep 25, 2008 | 12:38 PM
summoboy's Avatar
summoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nice
what is the p-code#?
Old Sep 25, 2008 | 07:35 PM
CayenneS2083's Avatar
CayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really niceCayenneS2083 is just really nice
check for leaks, maybe a weld cracked?
Old Sep 25, 2008 | 08:30 PM
larry_chip's Avatar
code is P0455
I Reset it twice & it hasnt came back since. maybe shes all good now?
Old Sep 25, 2008 | 11:41 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
I did the same hack using a 2.25 inch ss pipe. NO CHECK ENGINE LIGHT.
At first i thought it was quieter, but after a few days it sounds awesome!!!!
I took it to the delaer to check the brakes and when the service tech brought it out he asked me: "Is that an aftermarket exhaust? That things sound deep and awesome."
Not bad for $80 and a little bit of elbow grease.
Thanks Gundo for the great pics!
Old Sep 26, 2008 | 07:37 AM
MLindgren's Avatar
MLindgren is a glorious beacon of lightMLindgren is a glorious beacon of lightMLindgren is a glorious beacon of lightMLindgren is a glorious beacon of lightMLindgren is a glorious beacon of lightMLindgren is a glorious beacon of light
Evaporative emissions would indicate gas cap not tight-should have nothing to do with tail pipe emissions.
Old Sep 26, 2008 | 03:34 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
If its saying there's an issue with the evap emmissions, theres a problem. Its not gonna go way on its own. Now if its the gas cap issue, the next refill and you properly putting the cap on tight will fix it. If you knocked a hose or fitting loose on the engine, you need to put it back on... make sure all the hoses are properly seated and not damaged.
Old Sep 27, 2008 | 02:11 AM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
Sounds more like a coincidental issue and not muffler related. Remember, you can completely remove the mufflers and still not get a CEL.
Isn't your pcar still under warranty?
Old Sep 27, 2008 | 10:28 PM
summoboy's Avatar
P0455 Fuel Tank Ventilation System (Major Leak) - Below Lower Limit
Potential causes:
- Tank cap missing or o-ring bad or missing.
- Ventilation lines detached from EVAP canister.
- Ventilation line detached from tank.
- Ventilation lines detached from operating vent valve.
- Ventilation line detached from fuel tank vent valve.
- Break in ventilation lines.
Old Sep 28, 2008 | 07:22 AM
Gundo's Avatar
Gundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud ofGundo has much to be proud of
Definite coincidence. There is no reason the muffler hack would give a CEL. Perhaps you loosened a cat during the process?
I like summoboy's summary - definitely related to the gas tank. Might just be the gas cap.
You should hear that exhaust in a cab - it's awesome!
Glad to hear you're enjoying!
COBB Tuning
Jan 1, 2025 09:02 AM
vr6tee
Aug 29, 2015 03:52 AM
HolmaN
Aug 19, 2015 07:32 PM
