Brake light out....how to replace?
Old Jan 7, 2009 | 11:03 AM
roadrat's Avatar
roadrat is infamous around these parts
I'm sure I'm overthinking this, but can someone tell me how to replace the right brake light?
Old Jan 7, 2009 | 11:22 AM
TT Surgeon's Avatar
Easy, mine has them go out all the time.
There is a phillips headed screw on the inner edge after you open the decklid, undo this then simply pull the lamp assembly out as a whole. Then remove the brake lt(usually the white terminal). Reverse.
Old Jan 7, 2009 | 12:02 PM
roadrat's Avatar
thanks!
Old Jan 7, 2009 | 04:17 PM
mnmatt's Avatar
mnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant futuremnmatt has a brilliant future
brilliant
What I love about this is how simple and easy and well engineered the light housings are, that they are are that quick to pull out, switch out the lamp and reinstall. Thanks Porsche for the great design yet again!
Old Jan 7, 2009 | 11:21 PM
dksu's Avatar
dksu has a spectacular aura aboutdksu has a spectacular aura about
how do you get access to change the headlight housing? I could never figure it out. I want to change out the stock hid bulb to an aftermarket one.
Old Jan 8, 2009 | 09:20 AM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
If I recall all lamp replacements are covered in some detail in your 'Owners Manual'.
Porsche even includes a little white plastic 'credit card' shaped tool for removing the lower front light housings.
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
ECS Tuning - BMW
Aug 21, 2015 02:00 PM
ECS Tuning - BMW
Aug 21, 2015 01:47 PM
TrackOne
Aug 20, 2015 12:56 PM
