V-flow VS X51 for NA 997
Old Jan 25, 2009 | 10:06 PM
nugent_crai's Avatar
nugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud ofnugent_crai has much to be proud of
it helps the engine to breathe air better, and colder air at that, ... it can only help!
Old Jan 25, 2009 | 10:08 PM
NorthVan's Avatar
Originally Posted by nugent_crai
its an intake, they all rate them at 10-15 hp
I would be surprised if the VFlo, headers and Cats give me more the 20Hp combined. I would save your money and spend it on the suspension, I found the overall performance of the car increased more with the Damptronics and sway bars, then the full exhaust/intake that I have. The cats provide the most gains of the exhaust mods, and they made the car sound a lot better.
Old Jan 25, 2009 | 10:11 PM
I already have everything except intake and chip at this point. Its an everyday car so I want to keep the suspension just the way it is, maybe with some swaybays but definitly not tightening up the suspension. I drove a car with some aftermarket suspension and it was a HARD ride, stiff as can be! would not be fun for everday use!
Old Jan 25, 2009 | 10:26 PM
Dave07997S's Avatar
Dave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant futureDave07997S has a brilliant future
My opinion on the intake is that unless you are going to do the throttle body along with the better intake manifold runners it probably by itself won't be worth much. You can get most of the benefit of the X51 package without doing the heads by doing the above. It will cost alot more than just the cost of the X51 airbox as you now have to buy the throttle body along with the intake manifolds. Also the install now just got a lot more complicated. If you notice however even the non X51 intake of the S is a dual intake setup, it is worth something but not much by itself. The X51 heads receive some bowl work and a stiffer exhaust spring so Porsche can raise the revlimiter to 7400rpm. At best there isn't more than 5hp with the better heads.
Dave
Paintballzen
Oct 10, 2020 12:22 PM
away
Sep 4, 2015 12:30 PM
John@SpeedTech
Sep 4, 2015 07:23 AM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
