Fabspeed header installation? Help!
Old Mar 25, 2009 | 01:52 PM
first911's Avatar
first911 is infamous around these parts
Guys,
I need some help with the installation of Fabspeed header on a 997S.
1. Do you have to unistall other pieces to be able to uninstall the factory header and install the Fabspeed header?
3. What torque to apply to adjust the header?
How long should it take?
Old Mar 25, 2009 | 01:58 PM
HATTRICK's Avatar
HATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of lightHATTRICK is a glorious beacon of light
Aside from the OEM header, you don't have to remove any other exhaust pieces.
Just installed the X51 headers this weekend on my back under the car. Took me 90 minutes total R&R.
Would be helpful if you sprayed the bolts with PB Blaster to loosen any rust on the cat flanges.
What year is your 997 ? The 05 has pressed threaded studs thru the cat flanges. Be careful when removing the 3 nuts off these studs.....if you snap a stud, you are fuc**d. Just take your time.
Tighten the header bolts to 17 ft/lbs.
Old Mar 25, 2009 | 02:07 PM
first911's Avatar
"What year is your 997 ? The 05 has pressed threaded studs thru the cat flanges. Be careful when removing the 3 nuts off these studs.....if you snap a stud, you are fuc**d. Just take your time."
My car is a 2005.... What can you do if you snap one...
Old Mar 25, 2009 | 02:18 PM
HATTRICK's Avatar
You'll need to get it drilled out.
Let me preface my 05S was an early production model and uses Gillett Cats...not sure if any MY production changes eliminated the pressed studs in the cat flanges to removable bolts......
Old Mar 25, 2009 | 03:56 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
My MY 06 (and I believe the same to be up until the MY 08) had removable bolts. It is recommended that you replace the gaskets and bolts. These items can be purchased through Suncoast and are inexpensive.
Old Mar 26, 2009 | 07:07 AM
leneuromancer's Avatar
leneuromancer has a spectacular aura aboutleneuromancer has a spectacular aura about
I snapped a bolt on removal of the stock, had to flatbed to a local indy for professional removal, was a few hundred $ - turns out mine wasn't a big deal but I sure stressed about it for a few days
Jun 10, 2017 07:45 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
oddjob142
Aug 19, 2015 12:27 PM
