Rear wheel fitment
Rear wheel fitment
I have been looking to purchase a set of Carerra S II wheels off of an 09. A wheel dealer has a set off a C4S. He told me the fronts are the same and the rears will also fit correctly other than the wheel will sit out one inch further, the same as a GT3 setup. I would appreciate any imput, verification or advice. I have an 06 C2S. Cheers.
and yes they will work on your c2s but have a more aggressive look (desired)
if you want to see what it will look like, look at a 997 GT3, it will look about the same
I suspect you need to consider the risk of tire rubbing if you ever lower the car. Having done so, with 5mm spacers (and no problem) I imagine 17mm would be getting pretty close. Particularly if you're running 305's.
Others on this forum would know for sure.
almost correct. the rear wheels of a c4s will sit out 17mm farther out than the stock c2s wheels. thats about 2/3"
PenguiN
Nov 12, 2015 05:24 PM
Sep 1, 2015 03:16 PM
ModBargains
Aug 20, 2015 12:28 PM
