XM Satellite install and antenna placement
Has anyone installed this XM kit from Suncoast and if so, how well does it work and where do you mount the antenna for an inconspicuous install?
Thanks!!
Thanks!!
I installed my antenna under the wiper cowl. It's black plastic to the RF signals will pass though it. Make sure the antenna is pointed up.
You also need to position it so it doesn't interfer with the wiper mechnism.
There is a hole with a grommet you can pass the antenna through. Works well and hides the antenna.
cnebrask
Oct 3, 2024 08:19 PM
r_matt_6
Oct 8, 2015 06:07 PM
