Possible Money Shift?
Old Jun 29, 2009 | 06:19 PM
mobonic's Avatar
mobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud ofmobonic has much to be proud of
Accelerating .. the rev limiter will kick in and starve fuel to the engine or sound like the car is spitting. The rev limiter will not allow you to blow the engine.
DOWN SHIFTING, there is no rev limiter, and this is how you money shift and blow engines.
Im pretty sure the DME only counts downshifts, as you cant really accelerate beyond the rev limiter, the computer won't let you.
Old Jun 30, 2009 | 07:00 AM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Originally Posted by 1999Porsche911
You have to override (or fool) the computer's rev limit setting. This is acceleration revs, down downshifting. Pretty safe in a hydraulic lifter engine as, most often, valves will float before something else gives.
Not sure I agree here. When valves "float", they are not fully opening and closing because the revs are too high for them to fully return to their positions. The result is the valves can contact the pistons. That is about the worst thing that could happen. Soon after that a rod goes out of the block and your engine is blown. Or a valve goes through a piston.
I'm not positive either, but I believe if you go full gas, hit redline, shift and stay on the gas and "speed shift", you can go over the limiter simply by the momentum of the engine carrying itself past redline.
Old Jul 1, 2009 | 12:48 PM
jhbrennan's Avatar
DME doesn't know if the over rev came from bumping up against the rev limiter (type 1) or a mechanical over-rev from a missed downshift. Rev limiter just keeps you from doing damage on the upshifts but will still record in the DME - I don't think the rev limiter is "smart" enough to stop revs right at the exact rpm limit.
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
Nov 25, 2015 06:40 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
