Are these scratches able to be fix to look less visible?!?
Old Sep 20, 2009 | 12:22 AM
europeankar's Avatar
europeankar has a spectacular aura abouteuropeankar has a spectacular aura abouteuropeankar has a spectacular aura about
Unhappy Are these scratches able to be fix to look less visible?!?
Old Sep 20, 2009 | 12:41 AM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
A good leather shop should be able to correct that, as it is coated leather.
Old Sep 20, 2009 | 06:18 AM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Might have better luck in the Detailer section of the forum. The leather can be made to look like new and the detail pros will be able to tell how.
Old Sep 20, 2009 | 03:29 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Those scratches can most definitely be corrected. I'm sorry, but without seeing/ feeling them in person, I can't offer you my insight into what technique and products you'll need, but it really doesn't look too bad at all.
I've seen much FAR, which required sanding and re-staining, but the final result was as new. I've done some leather sanding and re-staining, and with the proper technique and products, you can expect results so good no one would have known there was ever an issue. Leather is pretty easy to correct.
CATTMAN
Old Sep 20, 2009 | 06:06 PM
DW997s's Avatar
DW997s is a jewel in the roughDW997s is a jewel in the roughDW997s is a jewel in the rough
I think it could be a DIY fix. Check this link out:
http://classiccars.about.com/od/rest...ornleather.htm
NC 996TT
Mar 23, 2023 06:19 AM
bongnation
Sep 25, 2015 02:58 PM
Greehn
Sep 17, 2015 03:15 PM
nick49
Sep 13, 2015 05:46 PM
