Help with wheel fitment for C4S
Old Oct 20, 2009 | 05:01 PM
Obie1's Avatar
Obie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these partsObie1 is infamous around these parts
I found a nice set of used Techarts that are 19's. The front is 8.5, 38 et, the rears are 11, 52 et. Anyone know if these would fit a 997 C4S?
Old Oct 20, 2009 | 05:04 PM
Bara's Avatar
Bara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant futureBara has a brilliant future
the rear will be sunken in about 3/4" from stock since its a narrow body offset.
the front will stick out about 1/2 inch
Old Oct 20, 2009 | 05:10 PM
Obie1's Avatar
Shoot, I meant to write 48 for the front.
Old Oct 20, 2009 | 05:23 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Wait a minute, 19X11 et51 is the turbo rear offset. Still fits the 2S, easily fits the 4S.
Old Oct 20, 2009 | 07:13 PM
Bara's Avatar
sorry, read this too fast, you're correct, the rear will fit like stock.
the front with the 48mm will fit also but will be an aggressive offset so you're going to end up with a stock offset rear and an aggressive offset front wheel. about 10mm farther out on those fronts
Old Oct 20, 2009 | 09:39 PM
Obie1's Avatar
Thanks guys, really appreciate your help.
ModBargains
Aug 20, 2015 12:28 PM
Phoenix604
Aug 19, 2015 10:39 PM
cab83_750
Aug 19, 2015 12:37 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
