Porsche Factory Engine Testing Questions
Old Oct 22, 2009 | 09:45 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
Lightbulb Porsche Factory Engine Testing Questions
Tonight's NatGeo 'Ultimate Factories' building the 911, shows truly a modern car assembly facility of an iconic advanced sports car. Lots of innovative assembly methods and technologies.
The boxer engine is assembled with a rational mix of manual and automated assembly. The engine is 'cold tested' sans fluids, where I presume they rotate the crankshaft and measure pressures and friction. It appears though that the flat6 is not 'hot tested' as it is only fired for the first time as the car is driven out of the line for some basic and brief roller/dyno testing (limited to 75MPH). If this is indeed the case, break-in of these engines must be looked into with a new perspective. Are piston rings settled as the car leaves the factory?
I look forward to comments.
Old Oct 22, 2009 | 10:57 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
I'm wondering if they skipped the hot test in the show. From Porsche's virtual factory tour:
The pre-picked components are supplied to the various work stations in picking trolleys for precision manual assembly. Crankcase, pistons, oil suction pipe, water and oil pump, cylinder head, tappets, intake system and wiring harness are assembled with great care to form a finished unit weighing 200 kg.
The following hot test is the final step in the engine production process. The engines are first of all heated up to operating temperature and then subjected to a functional test including full-throttle testing. Information in the form of up to 220 parameters is generated in this test of around five minutes' duration.
This ensures that Porsche's high quality standards are also met in the area of engine construction.
Following subsequent connection of the engine to the transmission, the engine is ready for the "marriage" ceremony (connection of the drivetrain and chassis to the body).
http://www.porsche.com/usa/aboutpors...-f64229f6bd09/
Old Oct 22, 2009 | 11:15 PM
adias's Avatar
Nice catch. That's probably what happened.
Old Oct 22, 2009 | 11:19 PM
ntlgnt1's Avatar
My guess is they figured we already showed the cold-test and we're going to show the dyno runs at the end so leave it out. Most viewers wouldn't care about it, but us owners would love to have seen it.
Old Oct 22, 2009 | 11:21 PM
ntlgnt1's Avatar
Oh and the 75mph limit is because the car is not strapped down on the dyno...at least that is how it appeared in the show.
Old Oct 23, 2009 | 03:17 PM
gjnockie's Avatar
gjnockie is infamous around these parts
It appears from the show that they no longer hot test the DFI engines. Seems like ring seating is now up to the new owner?
COBB Tuning
Jan 1, 2025 09:02 AM
joseph_number1
Jul 19, 2018 05:45 PM
Fabspeed Motorsport
Aug 26, 2015 11:15 AM
Aug 21, 2015 06:34 AM
