Help ! US 997 C4S Lambda offset when on UK fuel
Old Nov 7, 2009 | 01:01 AM
ghsu's Avatar
ghsu is infamous around these parts
My 2008 US spec 997 C4S is now in the UK running on UK 98 oct gas which usually has less than 5% ethanol
Through PWIS we can see DME calculated the lambdas running between 0.98 and 1.02 (3,000 rpm). No error codes, DME thinks its doing a great job.
However from sniffing the tail pipe, the Lambda is reading a constant 1.05 (on both sides) which is out of the UK allowable range of 0.97 to 1.03. (Had this done in 3 different places, all the same result)
We have checked the AWE ehaust system (200 cell CATS) for leaks and are pretty confident that the sysytem is tight
Any info or comment on why the DME lambda is being calculated with a negative offset ?
US cars have a different part number for the upstream O2 sensor from the european cars. Downstream sensors are the same for US and Euro. Could it be that the US upstream O2 sensor is calibrated / optimized for fuel with 10% ethanol . . .?
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 18, 2015 03:41 PM
PelicanParts.com
997 Vendor Classifieds
Aug 18, 2015 03:39 PM
