|| VF-Engineering S/C Porsche Carrera 997 S 3.8 & 997 3.6 Holiday Kit Info! ||
VF-Engineering Porsche Carrera 997 S 3.8 & Carrera 997 3.6 Winter Holiday kit information!
VFE Supercharged Porsche 997S 3.8 & 3.6 kits in brief
The VF-Engineering designers set about designing the billet supercharger mounting bracket with CAD software creating solid models of parts to be CNC manufactured. The bracket was designed to utilize OEM bolt patterns and requires no alteration or relocation of any engine parts to be fitted. Made from 6061-Tx aircraft grade aluminum the bracket mounts to factory machined surface points on the aluminum engine block for a precision fit.
A V2 model Vortech Engineering supercharger unit was chosen after consultation with Vortech engineers and matching the engine's volumetric efficiency with supercharger compressor maps. The V2 unit contains helical-cut gears for super quite performance - virtually silent with the engine compartment lid closed. The V2 supercharger has a 20psi and 1000cfm maximum capacity and is an over-engineered part for this Porsche application which is geared to produce a conservative 6psi in the engine's intake manifold.
Engine management software was by written by GIAC with extensive testing performed on independent test cars. Multiple factors such as charge air temperatures, ignition timing, fuel trims, maps and injector performance were taken into account. The Carrera 2 and 4 test vehicles were extensively dynoed on the GIAC 4WD Mustang and monitored for wide band air fuel ratios at load levels often greater than would be experienced on the road. The results are an increase of 120 horsepower and 80 ft.lbs of fully useable torque.
VF-Engineering Winter Holiday SALE for Porsche Carrera 997 S 3.8 ( 04>newer)
Bolt on "ready to run" 6.0 psi VF-Engineering supercharger system VF Part # VFK60-01 {choose ONE option only}
Options 1) VFE 997 S 3.8 kit with FREE Ground shipping and FREE GoPro Hero Camera (with 2GB/SD card)
Options 2) VFE 997 S 3.8 kit with FREE Ground shipping and FREE Visa Gift card
Options 3) VFE 997 S 3.8 kit with FREE Escort Passport Radar Detector model# 9500IX
(**please contact us direct for any questions or other Hubert@vf-engineering.com / sales@vf-engineering.com )
VF-Engineering Winter Holiday SALE for Porsche Carrera 997 3.6 (04> newer)
Bolt on "ready to run" 6.0 psi VF-Engineering supercharger system [VF Part # VFK59-01 {Choose ONE option only}
Options 1) VFE 997 3.6 kit with FREE Ground shipping and FREE GoPro Hero Camera (with 2GB/SD card)
Options 2) VFE 997 3.6 kit with FREE Ground shipping and FREE Visa Gift card
Options 3) VFE 997 3.6 kit with FREE Escort Passport Radar Detector model# 9500IX
(**please contact us direct for any questions or other- Hubert@vf-engineering.com / sales@vf-engineering.com )
Our systems are complete and a true bolt on. They include:
Vortech V3 SQ supercharger.
Vortech Chargecooler.
Bosch high flow water circulation system.
Porsche OEM water radiator kit.
GIAC chip tuned with larger Bosch injectors.
Top speed governor removed.
Bosch pressure relief bypass system.
High temp molded polymer pipework
K&N induction filter.
1 year unlimited mileage warranty on supercharger kit parts.
Made in California, USA
VF Engineering has been masterfully creating Porsche Forced Induction Systems since 2003. With over 500 systems sold to market World Wide, there is no question of our quality and reliability.
-the goodie deals-
Escort Passport 9500 ix
PASSPORT 9500ix comes complete with comprehensive owner's manual, quick-release windshield mount, coiled SmartCord, quick reference card, and an ESCORT travel case. If you would like a more permanent installation for your PASSPORT 9500ix, check out the DirectWire SmartCord or the more basic DirectWire kit for hardwired installations.
9500ix details: http://www.escortradar.com/passport9500ix-details.php
Escort Passport 9500 ci
PASSPORT 9500ci comes complete with a comprehensive owner's manual and installation guide, installation DVD, separate miniature controller and text display, front-mounted radar receiver, twin front-mounted laser receivers/shifters, rear license plate mounted laser receiver/shifter, 12-volt interface module, GPS antenna, 12-volt amplified speaker, display bezel, bi-color LED, and all mounting hardware.
9500ci details: http://www.escortradar.com/store/passport-9500ci.html
GoPro Hero Camera
What's Included:
FREE Ground Shipping & Visa Gift Card
GoPro Hero Camera
What's Included:
- 1 HD HERO Camera (5 megapixel)
- 1 Rechargable 1100 mAh Lithium-Ion Battery
- 1 Waterproof Quick-Release Housing (180/60 m)
- 3 Flat, 3M Adhesive Mounts
- 2 Curved, 3M Adhesive Mounts
- 2 Quick-Release Buckles
- 1 Vertical Surface J-Hook Buckle
- 1 Suction Cup Mount
- 1 Three-Way Pivoting Side Arm Assembly
- 1 USB Cable
- 1 Component Video (HDTV) Cable
- 1 Composite Video + Audio Out Cable
- Warranty: One Year
joseph_number1
Jul 19, 2018 05:45 PM
