Oil Temp kinda low
Old Jan 1, 2010 | 04:59 PM
kosmo69's Avatar
kosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nicekosmo69 is just really nice
Oil Temp kinda low
The oil temp gauge on my 997.2 seems low to me. Its been cold here recently but even on the warmers days like today(54deg) the oil temp gauge doesnt read more than 175F. It doesnt seem to matter if im driving on the freeway or in traffic. It never goes above 175. I've always thought that 210f was optimal. the water temp is bang in the middle. something wrong here? tks
Old Jan 1, 2010 | 05:36 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
You are not exercising your engine enough and long enough.
175F for street driving is quite normal actually.
Old Jan 1, 2010 | 06:19 PM
kosmo69's Avatar
I see. Hmmmm? The last thing I want to do is start a OIL debate, but "I gots to know."
Since my engine is running below the 212 F (100 C) should go to a "thinner" oil?
Old Jan 1, 2010 | 06:25 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Your Porsche gauges are far from accurated. Your oil and coolant temperatures are considerably hgher than indicated by the gauges. Your engine temperatures cannot be as low as 175F after warmup.
Old Jan 1, 2010 | 06:33 PM
kosmo69's Avatar
the Bimmer + Fcar both read pretty close to 210F under similar condition so I think youre right. Going to have it checked out. tks
Old Jan 1, 2010 | 06:46 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
I tend to side with 1999, he knows more than most.
FWIW, running Mobile-1 0W-40, the gauges on my '05 997S are typically at:
Oil: 220
Engine: 175
CATTMAN
Old Jan 1, 2010 | 06:58 PM
Your coolant temperature is really 190F+ once warmed up and can rise to 215F+. Your oil will always be higher than your coolant temperature after full warm up. I think all 997 coolant temperature gauges peg themselves at 175 regardless of how much hotter your engine really is. Just another example of Porsche precision.
Old Jan 1, 2010 | 07:00 PM
adias's Avatar
You are fine. My brand new 997.2S on a 30 mile drive (normal driving) never got oil above 175F (50F outside temp). I've seen oil much warmer in other conditions.
Your oil and car are fine. Incidentally, if you constantly see oil at 220F or above... you'll have to change oil more often as very hot oil changes its properties. Same for tranny oil.
Old Jan 3, 2010 | 01:19 PM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
My 08 997 usually takes a solid 10 miles of highway driving to warm up to an oil temp of 200 F. That's with cruise set at 65 mph. If I start driving harder it will head up to around 215 F.
Old Jan 3, 2010 | 02:29 PM
1100S's Avatar
1100S is infamous around these parts
The oil temp on my '09 C4S runs significantly lower until very warm than the '05 C2S that I've had. I seem to remember reading somewhere (Excellence?) that the "new" engine has electric oil pumps instead of the usual mechanical. That means that the oil pressure is not necessarily related to the engine speed so in most situations will also likely be lower. This is supposed to create optimum pressure and less parasitic drag so more power. Maybe that is the reason for the lower oil temps we're seeing
Old Jan 3, 2010 | 02:40 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
+1...the gauges in your 997 are what I call dummy gauges. they are not accurate and coolant gauge is pegged at 175 no matter what.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
Rguy
Apr 12, 2020 11:11 PM
HotRod
Sep 10, 2015 07:17 PM
Fester
Sep 8, 2015 09:35 AM
