Airbag light came on. How to reset and possible problem?
Old Apr 2, 2020 | 05:58 PM
Carheli's Avatar
Carheli is infamous around these parts
Do you have a piwis
Old Apr 2, 2020 | 06:11 PM
AmericanPupusa's Avatar
AmericanPupusa is infamous around these parts
Piwis
Originally Posted by Carheli
Do you have a piwis
no I just used my icarsoft obdii scanner tool.
iCarsoft POR-II Porsche OBD-II Scanner Tool Multi-systems ABS SRS
https://amzn.to/2ZOkqR2
Old Apr 9, 2020 | 12:05 PM
MooseMichaels's Avatar
MooseMichaels is infamous around these parts
Originally Posted by keninirvine
If you disconnect any of the air bag connections, including the passenger bag warning light on the center console, and turn on the ignition while any of these are disconnected, an air bag fault light will come on and will have to be reset.
I just did the same while adjusting my shifter cables.
Is it possible to reset the light using a generic ODBII code reader?
Old Nov 7, 2022 | 11:11 AM
missmy6's Avatar
missmy6 is infamous around these parts
You can't reset the airbag light using a generic OBD2 scanner. The airbag codes are stored in the SRS control unit. Generic OBD2 scanners, read and clear codes from the Engine Control Unit (ECU) which has nothing to do with airbag codes.
If you are in the US, the cheapest way is to go to YOUCANIC website and rent their full system scanner. It's cheaper than going to the dealer. They ship it anywhere in the US. Plus you can use the scanner to diagose any other car / issue.
Old Nov 7, 2022 | 01:50 PM
Leftlaneleadft's Avatar
Leftlaneleadft is infamous around these parts
Airbag light
Originally Posted by Big_O
The airbag light came on. Took it to a local shop but he didn't have the SRS / OBD tool to reset it. Will a durametric reset it? Think it might be a seatbelt switch? Don't want to reset it and have the warning go away then not have it deploy if needed. Any ideas before taking it to the stealership?
Just FYI this happened on an old Mercedes of mine they could not find what the problem was a month later the airbag went off on the driver side window while driving on highway at night. So lucky no cars were around could not see from all the white powder coming out of airbag! This is a safety issue
Old Mar 12, 2024 | 12:04 PM
byroncheung's Avatar
byroncheung is infamous around these parts
anyone know is the airabag still function with the warning light on (after batter disconnect), if it is still functional i'll procrastinate, if it is not, it will have a higher priority on my todo list...
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
GSR Autosport
Aug 26, 2015 05:20 PM
oddjob142
Aug 24, 2015 05:49 PM
Walorus
Aug 18, 2015 01:39 PM
