997.2 Ipod question
Old Aug 4, 2010 | 10:10 AM
steve0827's Avatar
From: Waltham, MA/Southport,CT/Vero Beach, FL/Grosse Pointe, MI
steve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to allsteve0827 is a name known to all
997.2 Ipod question
I was driving my aunt's 2010 C2s cab. and was trying to hook up my iphone, but I couldn't seem to get it to play my music. She has no idea how to do it either. I plugged it in using the usb rather than using an aux cable.....I know that this works on her Lincoln MKS, so that's why I thought it might work.
Old Aug 4, 2010 | 10:15 AM
TooSixy's Avatar
TooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant future
Use the Y-cable (with both DIN and USB plugs). It will let you play music and charge the iPhone at the same time.
Old Aug 5, 2010 | 12:39 AM
steve0827's Avatar
Ahhh, thank you!
Old Aug 9, 2010 | 02:40 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
You can use a 2-conductor stereo 1/8" cable to plug it into the AUX input source (use the DISC button to select) on the universal audio interface, then select AUX from the PCM, and control what is played from the iPod.
OR as was said, use the car's iPod cable that plugs into the iPod doc connector and the other end into the DIN (round) connector on the universal audio interface input (and if the cable has the USB end, plug that into the USB port of the car to get charging power).. and then control what is played via the PCM ipod source (again, DISC button to select)
COBB Tuning
Jan 1, 2025 09:02 AM
Oct 14, 2015 07:00 PM
Sep 14, 2015 06:42 PM
Aug 21, 2015 09:56 AM
Aug 21, 2015 06:34 AM
