How do you park and lock the wheels of a manual transmission car?
Old Sep 27, 2010 | 10:16 PM
akacaj's Avatar
akacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to beholdakacaj is a splendid one to behold
When the car is off you can still press the clutch down and get out of gear. Any way to prevent this so that I can park with my cab down and not worry about some ******* throwing it in neutral on a hill?
Old Sep 27, 2010 | 10:19 PM
frankie997's Avatar
frankie997 is infamous around these parts
There is no other way.What you can do is turn the wheels toward the curb so that if it does happen the car will only roll into the curb.
Your best bet is to leave the windows up or the top up. other than that you are taking that chance.
Old Sep 28, 2010 | 11:09 AM
EJ-997's Avatar
EJ-997 is infamous around these parts
the steering column is automatically locked when the key is withdrawn from the ignition lock. So if your front wheels are pointed toward the curb you should be ok.
Old Sep 28, 2010 | 11:33 AM
utkinpol's Avatar
utkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond reputeutkinpol has a reputation beyond repute
if you park on a hill by a rules you have to turn your front wheels into carb side and engage handbrake.
Old Sep 28, 2010 | 02:16 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
Parking a 6spd - put on the parking break. If the incline is steep, you angle the tires so the car would roll INTO the curb, and set the shifter in either 1st or Rev depending on direction of incline, AND the parking brake.
With the top down, you cannot prevent someone from shifting into neutral and releasing your parking brake. However, the ignition lock will prevent the steering wheel from being turned and that should limit the roll to the point that the downhill curbside wheel contacts the curb.
Old Oct 2, 2010 | 09:28 PM
akacaj's Avatar
Thanks for your input guys. It just occurred to me that you would have the same issue with an automatic transmission which can also be thrown in neutral if the car is off. Being that this is my first cab and stick, I never had to deal with this issue before so I automatically blamed it on the manual transmission. Turning the wheels is a good suggestion but I guess the best bet is to close the roof. I do have SmartTop so its not that big of a deal.
Old Oct 4, 2010 | 02:37 PM
Minok's Avatar
Turning the wheels, if the incline is step, isn't just a suggestion, its highly recommended.
If the parking brakes fail or the gear lever slips, it keeps the car from going downhill.
COBB Tuning
Jan 1, 2025 09:02 AM
PenguiN
Oct 26, 2018 07:23 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
Phoenix604
Aug 19, 2015 10:39 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
