Wheel offset question
Old Nov 22, 2010 | 10:52 AM
murox's Avatar
murox has a spectacular aura aboutmurox has a spectacular aura aboutmurox has a spectacular aura about
I am about to buy a set of 19" Turbo wheels for my 997.2 base Carrera (narrow body). Just making sure the offset is correct for my car.
Wheel width: 8.5 Front and 11.0 rear
Offset: ET.55 front and ET.67 rear
Also, my car came with the 5mm spacers from the factory. Should I leave those on?
Thanks!
Old Nov 22, 2010 | 10:55 AM
Axxlrod's Avatar
Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !Axxlrod Is a GOD !
Those are the correct wheels for that car. I would definitely leave the spacers on. In fact I would get thicker spacers, but that's just me.
Old Nov 22, 2010 | 11:05 AM
murox's Avatar
Thanks!
Old Nov 22, 2010 | 11:19 AM
topspd's Avatar
topspd is infamous around these parts
Actually, the stock offsets are 19x8 ET57 front and 19x11 ET67. If the turbo style fronts are actually 8.5" wide with a 55 offset then they will extend in by an extra 4mm and out by an extra 8mm. You may want to do a test fit and see how it looks with your spacers as your fronts will stick out 13mm and your rears only 5mm.
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
