Rear Brakes Squealing
Old Nov 23, 2010 | 10:38 AM
drkside's Avatar
drkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to alldrkside is a name known to all
I have getting a squeal from my rear brakes and and I trying to figure out the exact issue. When the car and wheels are freshly washed, no issue. Even had my mechanic take a look the day after the car was washed, and he said they appear to be fine. Full brake pads and the rotors seemed to have no major issue (said I might want to consider replacing next time I do the rear brakes). After a few days of driving, the noise came back. I am wondering if the pads are the issue and the brake dust is causing the squeal. Anyone ever experience a similar issue?
Old Nov 23, 2010 | 11:34 AM
NorthVan's Avatar
I have had this from time to time, it gets solved by hitting the brakes hard a few times in a row at highway speeds.
Old Nov 23, 2010 | 01:45 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
Pads are glazed with the rotors....it happens on sports cars like this.....Do a few hard stops from say around 70mph down to 30...real hard..get ABS going as you've got to heat up the brakes and transfer some pad material to the rotor.
Old Nov 23, 2010 | 03:21 PM
drkside's Avatar
Thanks for the help. I am off to try this.
Old Nov 23, 2010 | 04:47 PM
Havoc'n'Hijinx's Avatar
Havoc'n'Hijinx is infamous around these parts
I have noticed my rear brakes squealing since having my front brakes (rotors and pads) changed at 30k, I will also try the remedy on my Thanksgiving drive and post my results.
I thought it was because the front breaks are new and pressing harder on the rotors than the rear pads on their respective rotors, and the lighter pressure causes the noise. Or am I wrong?
When I stomp on the breaks instead of smoothly pressing, the squeal stops quicker.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
rnl
Aug 26, 2015 02:36 PM
The Oss
Aug 24, 2015 08:19 PM
