does OEM 2010-2011 GT3 rear bumper fit to 05-08 Carrera s?
Old Nov 25, 2010 | 09:18 AM
like7272's Avatar
like7272 is infamous around these parts
does OEM 2010-2011 GT3 rear bumper directly fit to 05-08 Carrera s?
do I need heat shield and any other parts?
Old Nov 25, 2010 | 11:04 AM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
I am going out on a limb here and going to say....THAT it will NOT bolt-on without modification.
If I am not mistaken the tail lights are different and I am almost positive THAT the bumper brackets are too!
IF I were to do it I would buy the GT3 rear bumper brackets because the heat shields ARE incorporated into those...at least for the two sides.Then you are going to have to figure out exhaust......you could modify existing mufflers that way you probably wouldn't need heat shields for the back!
Cheers ,
Stacy
Old Nov 25, 2010 | 01:11 PM
Jack667's Avatar
Jack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant futureJack667 has a brilliant future
I'm not sure about OEM, but it does seem like there are some great options available for the .1 cars, wanting a conversion like you're speaking of, from aftermarket vendors. There are some threads here on the board, and it looks like you could go with center exhaust or stock dual exhaust. Then order the .2 lights from Suncoast or elsewhere and you'd be set. Not sure about heat shield, but someone like v35 ought to know.
I'd like to do that myself, but I'm bogged down by another issue until the spring that's starving my spare cash. I'd like the .2 lights, GT3-type bumper, probably euro look wrt bumperettes. Not sure I like the Euro license plate thing, but I'm not going to get hung up on that. Also not sure I want to go with stock or center exhaust. I'll sort it out by the time I get the funds in order, though...
Good luck with your mods.
Jack
Old Nov 25, 2010 | 02:33 PM
like7272's Avatar
Thanks to all
I decided to go with aftermarket rear bumper
I will post some pics after I put them on
2lflat4
Nov 18, 2019 05:05 PM
joseph_number1
Jul 19, 2018 05:45 PM
awdbiturbo1
Feb 18, 2016 10:24 AM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
