997.2 Front Lip Removal ??
Old Jan 6, 2011 | 07:41 PM
echere88's Avatar
echere88 is infamous around these parts
Hi,
Run into the curb, now middle section of front lip (plastic part under the front bumper) come out of bumper. Try to force it back, no luck. I took a close look, and found out the whole lip could slide out and push back in. However, there is one screw at the end of the lip needed to be taken out, so the lip can be dis-engaged from the bumper and slide out. The screw is located at left end of front lip. But, here is the problem....I can try to unscrew it, but the screw will not come out. I don't think the screw is damaged.
Anyone has experience removing the front lip for 997.2? Does the whole bumper need to come out, so you can remove the screw? By the way, I already search the forum and know that 997.1 has two screws at each end. 997.2 is different, only one screw at left end.
Thanks for any input.
Old Jan 7, 2011 | 10:45 AM
Justahonda's Avatar
Justahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud ofJustahonda has much to be proud of
Try putting some downward (tugging) pressure on the fastener as you try to remove it. Should do the trick
Old Jan 9, 2011 | 12:51 AM
echere88's Avatar
Thanks, it works. Operation Successful.
Old Jan 9, 2011 | 10:01 AM
Justahonda's Avatar
Good to hear!
Lowtush
Jan 25, 2022 10:48 AM
albert@velosdesignwerks
BMW //M
Aug 22, 2015 07:17 PM
