Found oil in throttle body 997.2 S
Old Jan 17, 2011 | 04:42 PM
ZoSo_DXB's Avatar
ZoSo_DXB is infamous around these parts
Hey everyone,
Title sums it up,
Yesterday i was removing my filter(cleaning) and found a small amount of oil on the back of the throttle body valve. Wiped it off, drove the car around and after a drive time of about 2 hours with some WOT accelerations, the inside of the throttle body has oil again. No puddles or anything its just a tiny amount that seems to be on the back of the throttle valve.
i would appreciate any help since i couldn't find any info on the issue after searching.
Old Jan 17, 2011 | 06:10 PM
cbzzoom's Avatar
cbzzoom is infamous around these parts
This could be a sign that the AOS is not functioning correctly. Obviously it's not a full AOS failure or it would be much worse.
A quick search indicates this can happen if the AOS seals have a small leak.
Old Jan 17, 2011 | 06:25 PM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
Maybe you over-oiled your K&N filter. Get a clean paper towel or rag and dab all the excess off the filter.
Old Jan 17, 2011 | 09:08 PM
ZoSo_DXB's Avatar
thanks for the reply,
Im sure its engine oil and not from the filter.
Is there any other sign or symptom to look for in order to be sure its the AOS thats going bad?
Old Jan 17, 2011 | 09:47 PM
cbzzoom's Avatar
Vacuum at the gas cap
Oil smoke from the exhaust
Oil in the tube from the AOS to the TB
turbotuner20v
Sep 11, 2015 12:02 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
magoochi
Aug 23, 2015 05:54 PM
