how to cure Pagid brake pad noise?
Old Jul 3, 2011 | 02:40 PM
antonio 997's Avatar
antonio 997 is infamous around these parts
Hi,
I wish to know your remedies on how to silence squelling Pagid brake noise? I go thte car with them, almost new pads. If it helps, they are yellow. i only happens after i drive for 20 minutes with the car. Basically, when the pads warm up.
Thanks for your responses.
regards
Old Jul 3, 2011 | 04:01 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
I'm not trying to be a smart a$$ but if you want to get rid of the noise, use oem pads. All racing pads, which is what a Pagid Yellow is, make noise in street use ranging from annoying squeaks to garbage truck bad squeals which is why many racers who also use their car on the street switch back and forth. It just depends on how bad you feel you need them and how much annoyance you can tolerate. Btw, Porsche makes fantastic brake systems so unless you are really a track rat with an identifiable need, you probably don't need anything else. Best.
Old Jul 3, 2011 | 04:57 PM
KonaKai's Avatar
KonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud ofKonaKai has much to be proud of
also the pagid yellows will eat through your rotors quicker than OEM, and there is no reason to tolerate that unless you're the aforementioned "track rat"
Old Jul 3, 2011 | 05:28 PM
mdrums's Avatar
mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !mdrums Is a GOD !
You cant...race pads like the Yellows lack the 2 weights per pad and the compound is not suited to the street.
Actualy for driving on the street, even spirited driving and auto-cross the stock pads are better.
You will never ever get enough heat in race pads on the street for them to work properly.
Old Jul 3, 2011 | 07:28 PM
DocMartin9's Avatar
DocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud ofDocMartin9 has much to be proud of
Ditto
The good news is that the pads are easy to change. You can swap out stock pads for the Pagid Yellows when you change over to track tires for a track event, if that is your bag.
Otherwise you are better off with stock pads for the reasons mentioned above.
Don't bother trying new dampers, caliper lubricant, etc. It doesn't work.
Old Jul 4, 2011 | 06:32 AM
jacques1960's Avatar
jacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nicejacques1960 is just really nice
I'm not sure I agree; the Pagid yellow pad noise is really an issue of modulation - try braking a bit harder and you may find that the noise issue goes away
Old Jul 4, 2011 | 01:16 PM
zoomzoommo's Avatar
zoomzoommo is infamous around these parts
To reduce noise, it's helpful to bevel the Pagids similar to the factory pads. I run my RS29's full time, and they seldom squeal.
While I agree that the OEM pads are better suited for DD and AX use, the Yellows CAN be used year round. Yes, they will be harder on the rotors, but (for me) track days will be the real reason the rotors require replacement.
I like the simplicity of not swapping pads. Been there, done that. And Castrol SRF extends my brake flush intervals. Perhaps I'm just turning lazier as I age :-)
Feelgood MD
Mar 24, 2016 09:35 AM
ModBargains
Audi Vendor Classifieds
Oct 13, 2015 03:45 PM
XLR82XS
Oct 5, 2015 07:02 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
