Intermittent high RPM Power loss & "Sport Mode Failure"
Old Mar 21, 2012 | 02:23 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
UPDATE: I finally got the car into the dealer with the fault, and the ECU reads that there is a Throttle Valve Control Module fault. The tech reset all codes and sent me home, to report if the fault returns.
Anyone have any experience with Throttle Valve module fault? I assume its just a plastic unit mounted somewhere. Anyone replace this part before?
Old Mar 31, 2012 | 12:44 PM
IslandS62's Avatar
RESOLVED
It was the throttle body/e-gas valve that failed, or was failing. Installation was very easy, remove the airbox, unplug the throttle body, remove 4 e-torx fasteners, replace gasket and install new part and reassemble. 20 minutes tops.
The X51 uses the same 82mm throttle body as the GT3 and, it seems, some Cayennes. Part #s are as follows: TB - 997-605-116-01 Gasket - 997-110-319-40
Throttle body is about $325.00 online for "genuine Porsche" and I found OEM Bosch for about $25 less. FWIW the original part that come off my car was clearly marked Bosch, so I would not be afraid to just save the $25 and get the OEM.
Thanks for all the help and advice guys. Happy to have the car at 100% again.
Old Mar 31, 2012 | 10:36 PM
p's pcar's Avatar
p's pcar is infamous around these partsp's pcar is infamous around these parts
Glad you're up and running again. Was that you I met at C&C a few weeks ago with the M5? I was with my son in the Atlas Gray C2S.
Old Mar 31, 2012 | 11:23 PM
IslandS62's Avatar
Yes, that was me. Hope to see you out there again this sunday!
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
Jun 10, 2017 07:45 PM
