Help with wheel offset...
Old Mar 8, 2012 | 06:23 PM
///MJFDDS's Avatar
///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute///MJFDDS has a reputation beyond repute
Anybody know if it is possible to calculate the wheel offset by just the backspacing? I am interested in some 3 piece wheels , but the offset is not stamped on the wheels. The specs are:
8.5x18 with 6 7/8" backspace
11.0x18 with 7 3/8" backspace
Guy says he used them on his 993 C2s with spacers. Just wondering if I can get them to fit on my 997 C2S.
Any insight would be appreciated.
Old Mar 8, 2012 | 07:12 PM
johnstoy's Avatar
johnstoy is infamous around these parts
I found a page at Mickeythompsontires with a conversion between backspace and offset.
Not surenifnthis cut and paste will work:
TO CONVERT OFFSET TO BACKSPACING:
For positive offset wheels: (Wheel Width +1)/2 + (offset * .03937)
For negative offset wheels: (Wheel Width +1)/2 - (offset * .03937)
TO CONVERT BACKSPACING TO OFFSET:
Backspacing – (Wheel Width + 1)/2 * 25.4 = offset
Hope this helps.
Old Mar 8, 2012 | 09:35 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
As an example on an 11" wide wheel the centerline for a zero offset would be 5.5", 1/2 the width. Take the backspace you noted and subtract 5.5" (zero offset) from the backspacing of 7 3/8". You get 1.875" as the offset. Convert it to millimeters by multiplying by 25.4 and you get 47.6 as the offset.
Old Mar 9, 2012 | 08:48 AM
///MJFDDS's Avatar
Thanks for the replies guys.
Old Mar 9, 2012 | 09:45 AM
damon@tirerack's Avatar
Moderator
Here's our link on offset.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Zero911
Aug 24, 2015 06:51 PM
Aug 21, 2015 09:56 AM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
