oil plug crush ring
Old May 21, 2012 | 08:47 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
oil plug crush ring
can t find 2009 oil plug crush ring... How many times can one be reused? Waiting for a Pelican callback... I ve re used them on other cars.
Old May 21, 2012 | 09:03 AM
spiffyjiff's Avatar
spiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud ofspiffyjiff has much to be proud of
i've reused mine but only once. i dont see the problem with once but as i've learned in the past (read: i'm an idiot and have proven it over and over again), it's better to follow porsche's recommendations more often than not.
try suncoast, i never have a problem when i order them.
Old May 21, 2012 | 09:37 AM
Boosted Josh's Avatar
Boosted Josh is infamous around these parts
Is it a copper crush washer? or actually a crush ring?
I'll reuse a crush washer, but if it is the ring I believe they are designed to be used once.
Old May 21, 2012 | 10:25 AM
cerbomark's Avatar
Don t know, trying to get everything needed for first oil change.
Old May 21, 2012 | 10:29 AM
tonka858's Avatar
tonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud oftonka858 has much to be proud of
bring one to your local napa they should have them
Old May 21, 2012 | 10:47 AM
djantlive's Avatar
Dealer and auto supply store have them too. You can reuse then at least once or twice. Try flipping them
Old May 21, 2012 | 12:27 PM
jhbrennan's Avatar
It doesn't look like copper, more like aluminum.
Old May 21, 2012 | 02:24 PM
damon@tirerack's Avatar
Moderator
reuse it. It'll be fine if used a second time. I do it all the time and have never had one leak.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old May 21, 2012 | 02:26 PM
cerbomark's Avatar
Pelican called back and I ordered filter and ring. On the 997.2 my oil filter is on top under back cap type filter holder. Question/ I don t see why I can t just use a 36mm socket to remove from the center nut. The porsche tool covers the whole piece to remove. I do this on my chevy which has the same type filter. On my mercedes I used a band tool as there was enough room and this also has that type filter housing. Thanks.
Old May 21, 2012 | 03:00 PM
I actually should have asked if it has a ridge on it that crushes when you use it.
If so those are designed to help you not over torque the drain plug. They aren't really to keep it from leaking.
Old May 22, 2012 | 12:56 PM
stronbl's Avatar
stronbl has a spectacular aura aboutstronbl has a spectacular aura about
Smile
Use the 36mm socket. If you look in the oil filter housing it specifies the size and torque). If you stare at it long enough you should see the info.
Old May 22, 2012 | 01:22 PM
cerbomark's Avatar
I got the dealers answer that it s a 36MM also to remove the filter housing. 8mm allen for the drain plug. My confusion was coming from reading about special filter tools which are applicable on the 997 not the 997.2.... The first time is always the toughest. maybe I ll do a DYI with pics when I do the oil and brake fluid on the 997.2. Thanks all.
Old May 22, 2012 | 08:03 PM
Macster's Avatar
It is not a crush ring, but a sealing ring. It is made of a special alloy (silicon/bronze IIRC). It does deform a bit from the drain plug biting.
The ring should not be reused.
For a used ring, if the side that has a ridge (from the the previous use) is placed against the oil sump drain plug hole's sealing surface will damage this critical sealing surface and the next time even if you use a new ring oil can seep past the sealing ring from this damage. Some more torque might be used and then the drain plug threads or drain plug hole threads are stripped. All for the lack of renewing this critical sealing ring.
If the ridge is facing out the risk is the drain plug may not fall back into position and the plug is ****ed, part of the drain plug is on the ridge, part is off the ridge.
This too can leak and more torque can only put the threads at risk. More torque can also cause the quite hard ring to break.
If this happens a seep is the best thing that can result. If the ring breaks the drain plug can come loose and if it falls out...
Sure many reuse these but they are playing with fire.
Visit a local Porsche dealer parts counter and buy a dozen if you can't get other places to supply you with the right parts to do a correct oil/filter service. The rings cost less than $2 each (less last time I bought some) for crying out loud. Not like having some spares on hand will break the bank.
While you're there, buy a spare drain plug too, just in case. Carry it in the car.
Sincerely,
Macster.
Old May 22, 2012 | 08:27 PM
kouzman's Avatar
kouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant futurekouzman has a brilliant future
check with suncoastparts too. that's where i bought mine from and being **** with my oil changes i bought the washer and new bolt too....
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
ModBargains
Maserati Vendor Classifieds
Oct 13, 2015 03:46 PM
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
