knocking noise under passenger seat issue?
hi all,
anyone have experience with a knocking noise that is coming from the undercarriage of the passenger side seat?
I wanted to look under but it is covered with plastic.
any thoughts before i go to the dealer?
thanks
thanks
If it only happens at speed....then I would say that one of the bolts/nuts from that plastic has come off and it is flapping in the wind and hitting the under carriage.If it happens all the time.....being that that the coolant lines are made from rigid material,maybe one those bolts has come off and the pipe is hitting the under carriage.I wouldn't worry too much,there is much under there and should be a simple fix......
Stacy
Stacy
or if something small and metal rolled under your pass seat, there is a gap/hole of sorts where things can get trapped and roll around under the pan. again, if happening at speed or over bumps or something, that's what you may be hearing.
pwdrhound
Aug 23, 2015 07:36 PM
riozilla
Aug 21, 2015 11:34 PM
